need help removing drive shafts
well taking the engine out today got everything and ready to pull motor except for the drive shafts . got them off the hubs but they are being stubborn to remove from tranny. any ideas or tools u guys recomend besides brute force haha i tried that lol . i dont have air tools either wish i did.
I use a big flat head screwdriver. When you put the new axle in, make sure the C clip opens downwards, or at least it helped me the other day. Give a decent yank to make sure they are in. I put a little grease on the hub side of the axle to prevent it from seizing, but do as you wish.
Keyword bolded. Usually they just pry out with a big screwdriver. Occasionally they just don't want to come out, usually seen most commonly on automatic civics that have suffered numerous neutral drops. If it doesn't pop out with a large screwdrive you're in for some serious work prying and hammering. If you can remove one i'd put a punch through the differential and hammer if out from the other side.
got iot out witha big screw driver the key was that u have to force it out from two side not just one otherwise it will come out uneven and get stuck .
the largest one i could find, i made it wider by beveling it in at the ends. it pops the axle before its fully around the shaft. just tap it behind her and give it a little pry action if needed. i also have a pipe to put arround it for added leverage.
rasinhell
Jan 13, 2005 09:52 PM
