want to boost my b18c gsr
Old Mar 23, 2009 | 11:28 AM
Brice72's Avatar
Default want to boost my b18c gsr
i finally have got my rod bearings and crank in for my civic and just ordered a new lip and tow hooks just for looks...but i am thinking of selling my truck and boosting my b18c gsr..i won't be running anything big i just wanna run like 8 or 9psi, so i know i shouldn't need to sleeve my block unless i go bigger and i might possibly need new new rods and pistons and possibly get hasport motor mouts as to the oem ones i have unless they will work with the set up, i was also thinkin of going with vitara pistons since eagle is so expencive. but i think i should be able to run my oem crank that i just got with it and i will try and buy a used oil catch can and fab. up about a 3in piping all the way back, as for the turbo piping i think 2 or 2 1/2in should be good for the intercooler piping (as for the a/c and p/s both have been removed) and i was probibly going to go with the skunk2 valves and retainers and see if i can run the stage2 skunk cams with..and i was just kinda wanting to know what would be a good turbo for this set up and kinda give me a feel for what other parts i am going to need... it would be very much appriciated for the help and as for askin if i should go for it or not..i am going to just need the help for the parts i will need and prolly as about installation as i go on.
I WILL BE POSTING PICS WITH MY NEW CAMARA AS I GET GOING ON THE BUILD
Old Mar 23, 2009 | 11:45 AM
Turbo-LS's Avatar
Default Re: want to boost my b18c gsr
wow your all over tha map with this dude. leave the engine stock for 8-9 psi of boost, DO NOT run skunk2 cams. there not for mild setups and will hinder perofrmance more than supply. just leave the motor bone stock and get a nice log like the blox or inlinepro and a garret 57 trim t3/t4 and you will be good to go
Old Mar 23, 2009 | 11:55 AM
Brice72's Avatar
ok so just run oem on the block and then run the 57 trim t3/t4 turbo and would 3in piping for exhaust be enough? and should i just run the DSM 450cc injectors or go with the 550cc? and thanks for the help i got questions that need answered befor i start anything
Old Mar 23, 2009 | 12:52 PM
Turbo-LS's Avatar
depending how crazy you get with base pressure for fuel but there generally good for about 300whp out of 450cc injectors. i would recomend the new bosch saturated injectors but if your on a budjet then the dsm's will suffice
Old Mar 23, 2009 | 01:04 PM
Death_to_Thieves's Avatar
My head hurts
Old Mar 23, 2009 | 04:46 PM
Brice72's Avatar
ha sorry school is boring so i wrote that in class...
Old Mar 23, 2009 | 04:56 PM
Brice72's Avatar
new rod bearings today!!!
next is injectors!
Old Mar 24, 2009 | 07:58 AM
Brice72's Avatar
found my injectors i will be getting possibly just want an opinion should i order the brand new BOSCH 725cc or 625cc injectors used?
Old Mar 24, 2009 | 07:21 PM
Brice72's Avatar
going to get my oil lines this weekend...ill be getting 36in of braided lines then hopfully i can order my manifold..
Old Apr 25, 2009 | 02:33 PM
0ne-Cam's Avatar
lol
Old Apr 25, 2009 | 04:20 PM
mycarslow's Avatar
way to bump a month old post one cam
061000rr
Sep 24, 2009 02:08 AM
jaydem_ekizzle
Jun 25, 2006 08:38 PM
ll Del La Sol ll
May 16, 2005 08:54 PM
95DXPhiladeph
Sep 26, 2004 01:06 AM
tinkerbell
Jan 7, 2002 08:56 AM
