Garrett T25 (What manifold works with it?)
Searched through the faq and found nothing, my friend is wanting to boost his single cam and he has a garrett t25 from an eclipse that he wants to use because it's free.
My question is, what manifold will work for him? I have a greddy d series manifold that i could sell him but i want to make sure what will work before i give hime false information. Thanks in advance
also check the turbine exhaust outlet. The T25 comes in MANY forms from the OEM applications. Even if its from a DSM. 2G DSMs, Nissan Z32 Fairladys, and even Pulsar GTis all come with a T25, but with different turbine housings and flanges. Caveat Emptor.
That uses a Radius flange. A circular opening with a 90 degree rotated rectangular flange on the turbine inlet, and a mitsubishi O2 housing on the turbine outlet. Those things don't even work well on the 2G DSMs much less your application, even a D-engine. You'd have to modify a manifold to even remotely have a chance to use it. Not worth the work.
It's free for a reason.
Ok thanks i'll let him know. It's free because his little brother had it lying around and had left to serve in the military and gave it to him. It was worth a try anyways. Thanks for the replies.
/thread
/thread
Hijack thread...... LOL. Since his question had been answered and mine pertains to it, what about this turbo for $50. The kid says it's a T25 and he had it on a prelude:
"No shaft play came off a prelude with a home made turbo kit upgraded to a 14b"
"The tip of the intake outlet was cut off for better fitment it still holds find turbo boosted nice and fast spooled loudly only reason it came off was to make more power"
Is it worth it to buy? I want to do a custom build (ghetto) on a stock mini me so my boost will be between 7-10PSI. Thanks.
Carolina Fried Rice
Aug 20, 2005 06:27 PM
