jdm window visors on 91crx w door mounted seatbelts !WILL IT WORK ?? PLEASE HELP!!
Old Mar 23, 2009 | 09:03 AM
efsedannva's Avatar
Default jdm window visors on 91crx w door mounted seatbelts !WILL IT WORK ?? PLEASE HELP!!
can somebody tell me if the jdm honda acess window visors will fit on my 91 crx with door mounted seatbelts?
i dont have power folding windows .
somebody please help!! and if they fit where can i pick up a set?
Old Mar 23, 2009 | 09:18 AM
scottmog's Avatar
Default Re: jdm window visors on 91crx w door mounted seatbelts !WILL IT WORK ?? PLEASE HELP!
you can pick up a set from ebay, thats where i got mine. if u want pics of them mounted just message me. i got some pics. i mounted the jdm ones onto my 90 crx si
Old Mar 23, 2009 | 11:47 AM
meandino's Avatar
hey put some pics up. I want to see this. did you have to modify them at all?
Old Mar 23, 2009 | 02:55 PM
efsedannva's Avatar
post the pics
Old Mar 23, 2009 | 04:49 PM
scottmog's Avatar
just get something and cut the the bottom back a bit. the angle of the front of the door is exactly the same, that doesnt need to be altered at all. what i did after was get some of the door molding crap you put on the end of your door so that you dont get dings
door trim crap
the cut
turn/bend explaination
scottmog's Avatar
wow i typed angel in stead of angle lol. oops!
Old Mar 23, 2009 | 05:24 PM
ESP.net's Avatar
Here is my thread read the last few pages: JDM EF8 Crx Visors will work with no cutting on the 90-91 Crx I simply took out the second clip from the bottom
Use a heat gun to liven up the adhessive on the visor, use alcohol to wipe down the trim area on the door that it will be attatched to. Heat up the trim area. Use some clamps for about 8 hours in garage for best results.
To loosen the clip 1 person to hold 2nd person with vis scripts gently work the clip back and forth till it comes loose from the visor. About 20 times back and forth gently dont want to harm the visor.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/90-91-usdm-crx-window-visors-modifying-jdm-ones-2195151/
Old Mar 23, 2009 | 07:35 PM
efsedannva's Avatar
thanks for the info im def. gonna pick up a set
hmonkey86
Mar 4, 2012 06:07 AM
cor4ey
21
Sep 12, 2009 02:46 AM
inaety
Sep 24, 2008 01:24 PM
leono
Aug 9, 2005 04:30 PM
Schaz
Sep 1, 2004 08:42 AM
