FS B16, whole or parts an D16 viatari pistons an springs
. Motor has less then 20k on it since rebuild, but one of the cylinders is low on compression, like 80psi So a bore, an new set of pistons will be needed.
The goods, eagle rods, srp pistons 81.5 bore with 9 to 1, has clevite bearings an oil pump was fresh at rebuild. ARP main an Head Studs, Head skunk2 dual valve springs an retainers, stock b16 cams in it . Oh yeah has cylinder brace also. Stock intake manifold is also avaliable. Head was checked when block was built, i found my reciept for work done to block an head, i 4 got but it had new valve guides an valve job done. Block was also line bored with the new arp main studs installed.
Head-$700
Rods an piston $300
head or main studs $75 each
Greddy kevlar timing belt $75 (like 220 new)
Block- make offer don't really want to ship it
Also for sale is a set of comp cams valve springs for a d series. part number, 912-16, spring rate of 50lbs when valves r closed 170lbs when opean, $125
opean to offers, please no low *****, feel free to txt me at 260 251 0459
Head-$700
Rods an piston $300
1qucksol
Nov 25, 2009 09:42 AM
1qucksol
Apr 29, 2009 06:13 PM
wade
Dec 20, 2006 05:36 PM
