... valve cover breather valve question? (turbo application)
Old Aug 13, 2002 | 10:29 AM
1.8T_EG's Avatar
Default ... valve cover breather valve question? (turbo application)
... okay, i did a search and the concensus is that a breather filter is bad and that the best setup would be a hose to the intake... my question is: if you have a turbo, what do you connect to the breather valve?... a breather filter?... or hose?... and if it is a hose, what do you connect the hose to?... lemme know... thanks...
Old Aug 13, 2002 | 10:37 AM
MyWhiteCivic's Avatar
Default Re: ... valve cover breather valve question? (1.8T_EG)
I'm pretty sure you can't put a hose into the charge pipe. Maybe right behind the filter but I just put a breather on mine.
Old Aug 13, 2002 | 11:12 AM
X2BOARD's Avatar
Default Re: ... valve cover breather valve question? (MyWhiteCivic)
Do you have a catch can setup ? If the answer is 'NO' do a search and read some...
Old Aug 13, 2002 | 01:21 PM
brcivic411's Avatar
Default Re: ... valve cover breather valve question? (X2BOARD)
although there is a better place for the catch can (inbetween the oil separator black box & Intake Manifold), you can put a catch can here.
Or, you can just connect it after the filter before the turbo.
to be safe, just get a small catch can
ac_attak
Jun 14, 2006 06:26 PM
djnikko
Sep 22, 2004 08:47 AM
Prelude91siT
Jan 1, 2004 10:42 AM
redtegger03
Jun 25, 2003 10:41 AM
supergreenNA1
Jul 16, 2002 03:20 PM
