Spotting dents with muticolored paint when sanding?
Old Mar 21, 2009 | 08:18 PM
-16V-'s Avatar
Default Spotting dents with muticolored paint when sanding?
A guys just wondering if anyone has tips for spotting dents with muticolored paint. For example my car is like 4 different colors due to sanding, and I'm wanting to repair small dents and such in the process. Should i just guide coat small areas at a time?? just seems like alot of work.
TIA
Old Mar 22, 2009 | 02:25 AM
gorillafart's Avatar
Default Re: Spotting dents with muticolored paint when sanding?
i'd go with the guide coat and coat the whole panel you're sanding so you can eventually sand the whole thing even
Old Mar 22, 2009 | 04:19 AM
19civic93's Avatar
Prime the whole car, put on a guide coat, then block the whole car. All the low and high spots will show.
Old Mar 22, 2009 | 07:45 AM
92cxturbo's Avatar
Old Mar 22, 2009 | 07:58 AM
blue2000em1's Avatar
when sanding with a car with a block dry or wet your old paint will work as a guidecoat. Wet is better because you'll see the areas dull and the areas still shiny are the low spots.Areas that broke to bare metal are high spots.
Old Mar 22, 2009 | 04:54 PM
precisionsc54's Avatar
The best and only way to do it right
Old Mar 23, 2009 | 10:55 AM
Okay so you prime the whole car,what do you've to do in order to have the primer adhere??? Sand it !!!! So why not water sand the car with a block like 220 or 320 Wet, and you'll start to see all the imperfections pop up.Then 36 or 80 the low spots and throw filler??Block that out with 80 finish with 180 your edges on the bodywork prime the vehicle??Guide coat it and block with 400 dry then follow with 600 dry.And paint the vehicle??
Old Mar 23, 2009 | 02:56 PM
You have the right idea. So go do it
r33dm0n3y
Paint and Body
14
Jun 15, 2009 04:53 AM
Green97EX
Paint and Body
May 1, 2009 11:35 AM
93beccalx
Paint and Body
Aug 12, 2008 09:14 AM
swappedcx
Paint and Body
Aug 13, 2007 05:52 PM
RHDintegXsi
Sep 16, 2006 05:13 PM
