Greddy blue box..................worth the time?
Old Aug 13, 2002 | 08:54 AM
eddie1681's Avatar
New User
Default Greddy blue box..................worth the time?
is it worth the time to install a Greddy blue box on a custom turbo kit?
Old Aug 13, 2002 | 09:08 AM
autoEXturbo's Avatar
Default Re: Greddy blue box..................worth the time? (b20z)
i personally think it did the job well with the greddy kit. If you step up to bigger injectors, the kit doesn't work as well. I think it's desinged to work with stock injectors. I would personally just go with the setup that inline pro uses. 440's, vortech fmu, map defensor, and a V or S afc.
Old Aug 13, 2002 | 09:57 AM
eddie1681's Avatar
New User
Default Re: Greddy blue box..................worth the time? (autoEXturbo)
what kind of power did they get out of the SOHC?
Old Aug 13, 2002 | 10:03 AM
i can't give actual hp numbers because i never dyno tuned here. This car is an automatic and when i just had i/h/e cam gear and pulley i was only pulling mid 17's. When i put the turbo on @ 5psi she pulled 14.9 almost 3 second difference. Well we are now at 8psi, but my automatic tranny is slipping so i can't give an accurate time. But she did a best on friday of 15.2. But now we are swaping to a gsr and plan on running low 12's high 11's right out the box.
Old Aug 13, 2002 | 02:03 PM
00TurboEX's Avatar
the Blue Box for the SOHC was actually worth the time, but as far as I have seen, the DOHC version for the SI is *almost* worthless. many people are having CELs and other trouble from the box. check out clubsi.com where they bash the SI blue box constantly. among other things.
david
Old Aug 13, 2002 | 03:54 PM
willyboyK20's Avatar
some guy on here is running 12's with a sohc and blue box with bigger injectors (310's) in a hatch at 10lbs
It seems that the dohc blue box just needs more fuel to compensate when u start to up the boost and let it breath more (i.e. bigger downpipe, bigger exhaust)
Old Aug 13, 2002 | 04:07 PM
FredoSP's Avatar
Default Re: Greddy blue box..................worth the time? (willyboyD16)
the 18G kit comes with 320cc injectors.
93TurboSi
Sep 20, 2003 02:01 AM
boostincoupe
Sep 1, 2003 12:29 AM
deviant1
Jul 30, 2003 01:48 AM
boostincoupe
Jul 24, 2003 05:35 PM
Ricey McRicerton
Apr 12, 2003 08:31 AM
