rear brake piston
Old Mar 21, 2009 | 05:22 PM
bibong's Avatar
Default rear brake piston
For some reason my piston is not turning when i turn it with a pair of pliers. The other side turns real good when i use that technique but the driver rear side piston is not even budging. Is there a specific tool that i need to compress the brake piston so i can install my pads. Please help.
This is regarding to a rear brake pad replace for a 98 integra.
Old Mar 21, 2009 | 08:01 PM
bibong's Avatar
Default Re: rear brake piston
am i in the wrong forum or something?
Old Mar 21, 2009 | 08:06 PM
90_EX_Civic's Avatar
go to autozone or advance or what ever(a little drunk to care). for sure autozone has it. it'll be in the tools section. look for a cube. it's meant for rear caliper pistons.
the cube is hollow. hollow enough to fit a 3/8 extension in it. you pick the right side that will fit on the piston. then use a ratchet to turn the piston. that is the only other tool i can think of besides a good set of channel locks or vise grips.
Old Mar 21, 2009 | 08:38 PM
bibong's Avatar
o itired autozone but that tool is not in there. Maybe ill check another autzone tomorrow for the cube tool.. Thanks man
Old Mar 21, 2009 | 08:59 PM
tilegend's Avatar
look like that even though i never used one.
you might also have rusted caliper pistons.
Old Mar 21, 2009 | 09:16 PM
RA429's Avatar
i just use a C clamp and put it one side on the outside of the caliper and the other side on the piston itself, then just tighten the screw as much as you need, then take it off. viola!
Old Mar 21, 2009 | 09:22 PM
tilegend's Avatar
the rear piston has a threaded shaft. its not the same as the front calipers.
Old Mar 21, 2009 | 09:53 PM
sp00ledbseries's Avatar
It will turn put some *** in it.
Old Mar 22, 2009 | 01:06 AM
94k24DC2's Avatar
Perhaps time for a new caliper?
Old Mar 22, 2009 | 05:15 AM
SQ is the SQUAD's Avatar
yea the caliper is prob seiezed. check the price on a new one. it may be cheaper to get a new one then start buying tols and repairing that one. i never knew those cubes where for the rear pistons. lol. learned something new.
you really cant use and anti sieze spray because it will eat away the rubber components.
Old Mar 22, 2009 | 05:59 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Yes, AutoZone carries the rear caliper tool, but in my experience none of the sides really fit the Honda rear caliper piston very well. I always end up using a big flat head screwdriver.
And no, a C-clamp WILL NOT work! Use that and you risk damaging the caliper beyond repair.
Old Mar 22, 2009 | 09:09 AM
bibong's Avatar
how hard is it to replace the piston, or is it chepaer to just replace the caliper itself.
Old Mar 22, 2009 | 09:15 AM
SlammedDC2teg's Avatar
Its cheaper to replace the caliper. It shouldnt cost more than 50bucks.
HondaJon
20
May 30, 2003 07:42 PM
flybert
Feb 9, 2003 04:25 PM
crxcess
Oct 9, 2002 10:50 AM
J T*
Apr 23, 2002 04:27 PM
D
Aug 6, 2001 06:21 AM
