Strut to use for lowered suspension?
Old Mar 21, 2009 | 05:03 PM
sbarmann's Avatar
Default Strut to use for lowered suspension?
I did some research but have not found an answer yet. I have eibach sportline lowering springs (~2.25" drop) but have KYB GR2 struts which are made for stock length springs. The problem I am having is that when installed I didn't even have to compress the spring in order to assemble the suspension b/c the lowering springs were so much shorter. Now when going over a sharp bump you can feel the strut bottoming out. I wanted to know if the KYB AGX were made specifically for lowering springs, that is the strut rod is shorter. Or, what strut should be used with lowering springs?
Old Mar 21, 2009 | 05:15 PM
93formula's Avatar
Default Re: Strut to use for lowered suspension?
i have agx's even in the instructions state that a drop lower then 2" will void the warranty. did you cut the bumpstops on your gr2's?
i know for da's you can use eg/dc front forks and either eg/dc shocks (they are shorter, allows more travel) this may be the case for ef's as well.
Old Mar 21, 2009 | 09:46 PM
sbarmann's Avatar
I did not cut the bump stops. I was trying to avoid buying hardware other than new struts. I looked up the drop rate and it is 1.7" in the front and 1.5" in the rear. How do you even cut the bump stops?
Old Mar 22, 2009 | 04:45 AM
jhammond_82's Avatar
Reject Papi
https://honda-tech.com/forums/suspension-brakes-54/
Old Apr 1, 2009 | 07:56 PM
sbarmann's Avatar
Alright, so I figured out that the Skunk2 struts and Koni yellows have a shorter shaft that will allow the top perch to be lower and thereby allowing my suspension to be preloaded. I couldn't figure out if tokico illuminas also have a shorter shaft like the other sport struts. If any knows let me know or if any uses Skunk2 struts let me know how they are. I appreciate the help.
Hondatypr636
May 10, 2014 12:31 PM
FSBxtreme
Nov 1, 2007 08:29 PM
staticrex
Nov 29, 2005 03:00 PM
JDM00SI
Jul 28, 2004 09:31 PM
kent
12
Apr 2, 2003 10:46 PM
