Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
passenger front door tapping noise
Old Mar 21, 2009 | 04:12 PM
soon2bdropped's Avatar
Default passenger front door tapping noise
hey whats up guys as you guy know i have an 05 accord 4dr lx. okay whenever u put the window down and up u can hear a tapping noise.. now its is very annoying because now it does it when your driving and the car hit any sewer cap or even pothole.. I took the door panel off the first time because im thinking oh okay the window itself is loose the 2 bolt that hold the window the the regulator/track. come to find it out they are both tight. As i was bring the window up and down u can see the window motor itself is tapping against the window when it goes up and down. Is that a common problem. what an easy fix without buying a new motor. I tried putting some felt(black foam type cushion against the motor so it wouldnt hit when u operate the window but i know thats not going to fix it. not only that my hands are to fat to get my hand down into the motor.Thank guys
Im counting of you guys.
Old Mar 22, 2009 | 05:05 PM
Default Re: passenger front door tapping noise
ttt... bump...
Old Mar 23, 2009 | 08:04 AM
Ross 2.0's Avatar
In a Junkyard near you.
Has the car been wrecked?
Old Mar 23, 2009 | 02:21 PM
yes on the drivers side not the passenger side.
Old Mar 23, 2009 | 07:40 PM
Ross 2.0's Avatar
just try bending the regulator away from the motor. The door or regulator is bent for some reason.
Old Mar 23, 2009 | 07:53 PM
Carcrazy1
Guest
Posts: n/a
The Foam set which holds the window is loosened,instead of packing up with bits of foam try to replace the whole set.I think it will work.
EM1_00Si
Jan 12, 2009 04:11 AM
i-VTEC_DOHC
Honda Civic (2006 - 2015)
26
Nov 10, 2008 06:41 AM
Lb1atx
Aug 29, 2007 08:14 AM
Serenity Now!
Jan 18, 2007 07:30 AM
