Car starts then shuts off instantly
Old Mar 21, 2009 | 12:47 PM
jimmysteezen757's Avatar
Icon2 Car starts then shuts off instantly
delete
Old Mar 21, 2009 | 12:57 PM
Default Re: Car starts then shuts off instantly
bump
Old Mar 21, 2009 | 06:18 PM
feraldarkness's Avatar
New User
Try this, as dumb as it sounds, turn to the key to the start position and hold it there, see if the car will stay running while you hold it in start "dont worry it wont damage the starter, the starter has an overun clutch that prevents that."
If it will stay running in the start position but not when you let it out of start you need a new ignition switch.
If that isn't it, check the computer for codes after it dies. The comp should be under your passenger side floor carpet, itll blink out numbers with pauses betwen codes.
Old Mar 21, 2009 | 08:00 PM
alscrx's Avatar
Main relay....
Old Mar 22, 2009 | 02:02 PM
goinghomesic's Avatar
New User
mine recently did te same thing, it ended up being the ignition switch
Old Mar 22, 2009 | 03:20 PM
graveltravel2's Avatar
sounds like the "electrical" part of the key ignition switch. aka a pigtail.
very easy to change out and somewhat affordable.
they are around 70 bucks OEM honda.
check out this link. http://techauto.awardspace.com/ignitionswitch.html
it will explain on how to check the origional solder points to see if they are damaged.
if they look bad, then replace the part. do not attempt to repair.
btw if you dont replace the part the "not starting" will get worse and the car will shut off while driving down the road.
Old Mar 23, 2009 | 04:09 PM
tried everything above. id hold the key on. it would just keep starting and dying.
Took it apart and tried again and it finally starts up. but now check engine light. blinks 5 times a little fast. mapp sensor???
Old Jan 1, 2012 | 06:23 PM
SCloudcroft's Avatar
Icon3 Re: Car starts then shuts off instantly
Thanks for not removing this thread. I found it and the reason my car is doing what it is.
Old Jan 1, 2012 | 06:32 PM
KINGVEM^^ED6's Avatar
Old Jan 2, 2012 | 02:15 PM
JDpower's Avatar
So it wasn't the ignition switch because from what you said that sounds like the problem.
Old Jan 2, 2012 | 05:50 PM
BigbamaBen's Avatar
I've had that happen before and the battery was too low to power the fuel pump
allgo88
Apr 5, 2010 08:50 AM
itslogz
Apr 4, 2010 08:21 PM
prelude504
Sep 7, 2009 03:19 PM
tampabitches
Aug 14, 2006 02:56 PM
buzlink
Aug 6, 2001 02:11 PM
