Saw botom half of a motor turn without top half turning. Damaged?
Old Mar 21, 2009 | 11:38 AM
Rude Awakening's Avatar
Daughter not possible
Default Saw botom half of a motor turn without top half turning. Damaged?
So, yeah, the bottom end of a motor had been hand turned, and the cams/vlavetrain did not turn. I know this because the VC was off. Would that motor be damamged from that?
Old Mar 21, 2009 | 11:51 AM
roycivic92's Avatar
Default Re: Saw botom half of a motor turn without top half turning. Damaged?
timming belt snapped
roycivic92's Avatar
what motor do u have
Old Mar 21, 2009 | 12:04 PM
98civdx's Avatar
Master Detailer
timing belt is prolly done
or it slipped off.
Old Mar 21, 2009 | 12:32 PM
roycivic92's Avatar
if its a sohc just put another one .it has no valve to piston problems ,now if its a b serious . good luck.
Old Mar 21, 2009 | 12:59 PM
MoreBoost!'s Avatar
Put another belt on and do a compression test
fiveSFE's Avatar
i think everyone missread the question here.
if you had taken the timing belt off of the motor and hand turned the bottom end, i doubt there would be damage done to anything, there was be ALOT of resistence if there was damage, and hopefully the person turning would have some sort of common sence.
that being said i have done this, without any problems
Old Mar 21, 2009 | 01:18 PM
forcefedferio's Avatar
no, unless of course, this is you....
Old Mar 21, 2009 | 03:45 PM
Its a F22B6 with H23A1 head.
There was no resistance. Timing belt was on.
Old Mar 21, 2009 | 03:58 PM
norburt's Avatar
New User
...did the timing belt turn?
as you turn the crankshaft, it rotates the timing belt which in turn rotates the camshaft assembly. If the camshaft assembly turned (along with your timing belt and crankshaft), then your valves kept timing and no harm was done to your engine.
If a valve was opened, and you turned the crankshaft without the camshaft assembly moving, the opened valve's cylinder would then proceed to push up and bend the valve. This would only happen with considerable resistance though (as was mentioned before), and trust me.... you'd know if it hit the valve or not.
killerpenguin21
22
May 24, 2009 03:29 PM
prettylew
Feb 5, 2008 07:08 AM
boostd ls
17
Feb 13, 2006 08:43 PM
2K_EK
Dec 23, 2005 01:31 PM
handa
Dec 4, 2004 07:21 PM
