oil temperature senders
Old Aug 13, 2002 | 08:27 AM
sk-itr's Avatar
Default oil temperature senders
I'd like to intall an oil temperature gauge into my car at some point and as I'm changing the oil soon it seems like a good time to fit the sender. I've read people talking about senders/sensors fitted into the stock drain hole in the sump. Am I imaging things ? If this is the case where can I get one from ? I understand that this may not be the best place to measure the temp from but I'd just like to know when things are nicly warm before taking it to 7,000 rpm onwards
Old Aug 13, 2002 | 08:32 AM
DutchITR1689's Avatar
Default Re: oil temperature senders (sk-itr)
Problem with the drain hole is that the sender will hang a bit down to the road.
It' very dangerous when you hit something with that sender, because you'll loose all the oil!!!!
Old Aug 13, 2002 | 08:43 AM
austrian type-R's Avatar
Default Re: oil temperature senders (DutchITR1689)
Greddy oil temp meter + Greddy sandwich plate for the professional and the cleanest loking. More infos on their web.
Old Aug 13, 2002 | 12:20 PM
sk-itr's Avatar
Default Re: oil temperature senders (austrian type-R)
Thanks - I'll take a look in the morning.
Old Aug 18, 2002 | 11:26 PM
sk-itr's Avatar
Do you need to use a non honda oil filter with this ? The gready site seems to suggest so.
Old Aug 19, 2002 | 04:47 AM
Track rat's Avatar
I've got a VDO 14mm x 1.5 (#323-055) sender in my drain hole. It is just a fraction larger than the drain plug it replaced and does not hang down below the pan.
Old Aug 19, 2002 | 04:50 AM
Default Re: oil temperature senders (Track rat)
In your drain hole or in your car's drain hole????? Hahaha
Have any pictures? Of you car's drain hole + sender!!!
Old Aug 22, 2002 | 05:21 AM
Track rat's Avatar
Can you provide an e-mail address via IM? I'll e-mail some pics.
Muckman
Oct 7, 2003 01:16 PM
BoostedH23a1
Sep 28, 2003 11:28 AM
austrian type-R
Oct 19, 2002 07:50 AM
