what headgasket are you guys using for boosted engines?
Old Mar 21, 2009 | 08:31 AM
949's Avatar
949
Default what headgasket are you guys using for boosted engines?
other then oem honda headgaskets, what other brands are there for the d16a6?
i was reading some of the post and some are saying a D16 headgasket will work on any D16 engine. is this correct?
Old Mar 21, 2009 | 09:10 AM
Garcia-Racing's Avatar
Default Re: what headgasket are you guys using for boosted engines?
D16z6 or cometic. not sure about the y8's though.
Old Mar 21, 2009 | 10:35 AM
949's Avatar
949
are the metal aftermarket h. gasket resuable?
such as, if i had to open the head a few times to inspect it for whatever reasons or will the gasket not reseal on the second or third time around??
Old Mar 21, 2009 | 12:04 PM
Not the best idea to reuse them, just replace it.
Old Mar 21, 2009 | 12:22 PM
AfTeRhOuRs209's Avatar
cometic FTW custom thickness < dope
Old Mar 21, 2009 | 12:30 PM
Cometic FTW
Old Mar 21, 2009 | 03:02 PM
949's Avatar
949
its custom?
so do i tell them what thickness i want before ordering?
how do i know how thick i need it to be?
Old Mar 21, 2009 | 03:31 PM
95LS1t's Avatar
Originally Posted by 949
its custom?
they have different levels of thickness, the thicker it is, the lower your compression, the thiner, the higher.
i would go either thicker, or oem thickness
everything should be on their website, or whatever place you're ordering from
Old Mar 21, 2009 | 04:09 PM
Teglove2's Avatar
oem ftw
Old Mar 21, 2009 | 04:20 PM
AbitAvenger's Avatar
oem
Old Mar 21, 2009 | 05:06 PM
BADGUYNY's Avatar
I would never touch Cometic.... go with OEM or Golden Eagle which uses OEM and just bores them out
Old Mar 21, 2009 | 07:15 PM
kte324's Avatar
I have used golden eagle with no problems, but I have also heard good things about cometic.
Old Mar 21, 2009 | 09:11 PM
streetracer6rpt's Avatar
Oem
Old Mar 21, 2009 | 11:21 PM
rocket256's Avatar
I went the Cometic cause that is what the shop had. But at the time I was gonna get a Golden Eagle gasket.
Old Mar 22, 2009 | 12:00 AM
92civicx's Avatar
oem
Old Mar 22, 2009 | 10:07 AM
949's Avatar
949
so far what i am understanding.
cometic lets you get custom thickness.
does golden eagle also let you custom the thinkness?
im also curious why doesnt the bottom end also warp when the engine overheats?
everyone seems to only point out that its the heads that are only warped when the engine overheats.
Old Mar 24, 2009 | 12:19 PM
explain why, they have the best reputation for pretty much every kind of car.
Old Mar 24, 2009 | 01:00 PM
Golden Eagle's Avatar
only OEM Honda gaskets here tested making over 1000 hp no problems
Old Mar 24, 2009 | 01:05 PM
ware do you get your info there is one reason we now cut oem gaskets and thats because we had nothing but problems with cometic gaskets been cutting oem gaskets for over 5 years now with no problems oem is hands down the best gaskets to run
Old Mar 24, 2009 | 01:10 PM
no we only use oem gaskets no no custom thinkness if you need custom thinkness cometic is the only way to go
Old Mar 24, 2009 | 02:23 PM
AJxr's Avatar
felpro mls
Old Mar 24, 2009 | 03:55 PM
civic-r11's Avatar
what about for a 85mm bore block.. i think that i am going to have to use cometic head gasket... if i could get e stock head gasket that size.. it wouldl be great..
Old Mar 24, 2009 | 03:57 PM
you can we cut oem gaskets and have 85mm bore in stock now
Old Mar 24, 2009 | 03:59 PM
marcj's Avatar
cometic because it was really cheap.. works great
Old Mar 24, 2009 | 06:45 PM
1qwkinline4's Avatar
in past experiences on a old single cam set-up....
I went Cometic cause it seemed like the right thing to do" Aftermarket Race item"
blew one within 3 weeks of my new set-up
then blew the next one after a month and half or so and I did have Arp's in..I got a tip to use OEM didn't really agree but the source was from someone thats had boosted cars for years....Tried it ran strong for 2 years until I killed a piston
OEM= FTW now just gotta figure out my 84.5 issue I'm gonna have?LOL
