Dyno comparison: ITR vs GSR cams.
Old Mar 20, 2009 | 07:21 AM
gringotegra's Avatar
Default Dyno comparison: ITR vs GSR cams.
I was quite amazed that the car picked up as much as it did with the cams. I was expecting 20whp maybe, but no i got much more!
Setup:
Stock GSR Motor 173k miles
AFI Street Series turbo kit (57trim)
ARP head studs
ITR cams
ITR valve springs
Blox IM
Tsudo 70mm Exhaust (i cheaped out here )
880cc injectors
E85
Street Tuned on Crome Pro
Max boost was 14.5psi. Duty cycle on my Tru-boost was 42% on the dyno for both runs. The rpm pickup for the last dyno run was not working so i do not know the TQ that it makes now, although im guessing its in the 270-280 range. Peak tq for the GSR cams was 262tq@6100rpm. both dyno runs only went to about 8100-8200rpm. The vtec dip has been fixed now.
Overall im pretty impressed with the ITR cams. But for the $320 i paied for the cams + valvesprings it was well worth it!
The car's best mph before the cams was 123.48, best new mph has been 125.65 at about 2600lbs <---- need to put the teg on a diet!
Old Mar 20, 2009 | 07:34 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Dyno comparison: ITR vs GSR cams.
im going to get retuned on the cams as well and should make about 450, stock GSR
Old Mar 20, 2009 | 08:19 AM
96 GSR-T's Avatar
Very nice, where does your VTEC engage now with the ITR Cams? Imagine what the gains would be going from GSR Cams to Pro-1's with the proper setup!
Old Mar 20, 2009 | 10:18 AM
Right now Vtec is @ 5000rpm, when i had the gsr cams it was 4500rpm... i still think we can lower it a bit to probably 4800...
Old Mar 20, 2009 | 10:33 AM
rocket256's Avatar
Nice numbers... I'm wondering how much HP you picked up just for using E85 vs 92-94 octane? Also how much more is E85 then 92-94 octane?
Old Mar 20, 2009 | 10:43 AM
Russyo's Avatar
E85 is usually cheaper, about the same as low grade fuel in most places as far as cost. its usually around 100 octane in comparison I believe, i could be wrong.
Old Mar 20, 2009 | 11:13 AM
blaze the chemi's Avatar
I think for long-term reliability on the valve train the ITR cams are great.
Old Mar 20, 2009 | 12:31 PM
Ls_dx's Avatar
Thats sick.
Old Mar 20, 2009 | 12:39 PM
Well i dont know about power , but i know that off the WG which is 10.5psi i did 343whp with the ITR cams/E85 and i trap 119mph, off WG without ITR cams i was trapping 117-118mph, on pump (92) off wg i would trap 114-115mph... all that was at about 2615lbs..
Old Mar 21, 2009 | 10:56 AM
portenio78's Avatar
Where did you get the cams? I cant find any place that sells itr cams?
Old Mar 21, 2009 | 05:13 PM
i bought mine off a friend that changed his ITR cams for some Sk2's...im sure if you looked around and called some shops you could find a pair easily...or you could bite the bullet and buy them directly from Honda ..atleast then you know they are brand new!
Old Mar 21, 2009 | 06:41 PM
eg:R's Avatar
was the gsr cam dyno on e85 also?
Old Mar 21, 2009 | 09:40 PM
yes sir
Old Mar 21, 2009 | 10:14 PM
Schister66's Avatar
Man U FTW
Nice...that makes me want to switch my cams before i tune this spring...
Old Mar 21, 2009 | 10:21 PM
it would probably be worth it!
Old Mar 22, 2009 | 03:52 AM
grndcont's Avatar
http://www.theoldone.com/components/...es%20Specs.htm
just bought one myself.
Old Mar 22, 2009 | 12:10 PM
90sedan's Avatar
Wow, nice gains. Definitely worth the $320 for 47whp haha.
Old Mar 22, 2009 | 03:07 PM
Yes it is definetly worth it!
Old Mar 22, 2009 | 10:15 PM
JFK78's Avatar
Looking good Myles - those are definitely impressive numbers for a bone stock GSR, especially on only 14.5psi w/a 57trim. Looks like TJ did a great job on the tune! We are looking forward to seeing all you guys down there again this summer.
Old Mar 22, 2009 | 11:05 PM
hey thanks man!! yeah man TJ did a good job! he always does... im in the same boat as Bryce now just broke 4th gear at the track last night
Old Mar 22, 2009 | 11:17 PM
JFK78's Avatar
Sucks to hear, I'd take this opportunity to shorten up your gearing and put a B16 3/4 in it, should improve your times/traps quite a bit!
Bryce and trannies just don't get along, haha!
Old Mar 22, 2009 | 11:23 PM
jdm602's Avatar
hey myles. guess who has a b16 tranny laying around.
noticed the thread and thought i should say something. this car rips. especially when im driving it!
Old Mar 23, 2009 | 06:14 AM
hahah yeah they dotn like him...im begining to think they dont like me either! I dont think i have the rpm to turn to meet the traps id like for B16 3rd/4th... i still have my old tranny that has 4th gear still good in it so i think im just going to switch that over...
**** for all i know youll want $800 for the tranny
it goes slower when you drive it
Old Mar 23, 2009 | 06:24 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
did you dial the cams in? or just threw them in and tuned?
Old Mar 23, 2009 | 06:34 AM
Dialed them in..
