Garrett t3 gt30r help!
Old Mar 19, 2009 | 10:57 PM
ntoxicatedtigah's Avatar
Default Garrett t3 gt30r help!
ok my friend has this garrett turbo that he just bought, its a 30r. thing is we can't completely identify what ar ect. it is. its t3 flange. only numbers we saw is 50 inside compressor housing, and 63 in the turbine housing. also on the compressor side its embroided garrett and all there is is a giant letter L symbol and a number 2. Also how do we test if the turbo is ok, it has very little play, nothing crazy, this turbo is brand new. thanks for your help guys, any other info you need ask, so that you can further assist us.
Old Mar 19, 2009 | 11:11 PM
Boosted_B_Series's Avatar
Default Re: Garrett t3 gt30r help!
Its a .63 ar exhaust housing, .50 ar compressor housing.. You can remove the covers and measure the wheels exducer with a micrometer and the inducer while your at it to give you a better idea on which 30r it is.
Honestly though, why bother, just run it. For what your needing it for knowing the housings sizes is enough. Its just a little 30r, there is no need to analyze compressor maps and compare measurements for a sub 500hp car.
Put a oil restrictor in it, hook the water lines up, bolt it on the car and build some boost. Check for oil, and look for smoke. To test it simply use it and enjoy.
30r is a great street turbo, spools great, has excellent response and makes decent power.
Good luck
dk
Old Mar 19, 2009 | 11:18 PM
thanks alot, but will that shaft play be ok? its minimal, also i was watching all the videos online, people could blow in it and the compressor would spin, mine doesn't. i can spin with fingers , but is it supposed to be that easy to spin by blowing?
Old Mar 20, 2009 | 12:10 AM
also to include, the compressor side has custom polished housing, and it looks like twin scroll. also the turbine housing doesn't have any garret etching on it. its a 5 bolt exhaust discharge. how do i identify this is a gt30r exactly?
Old Mar 20, 2009 | 04:43 AM
oneoverwrx's Avatar
you need to look at the center housing. There will be a little tag on there that says garrett and it will have some numbers on there. One of these numbers will identify the turbo.
Mine is a 700382-12
Also...the little play you are talking about is probably due to it not haveing any oil in it. My 30r works perfectly and has a very very small amount of play. As boosted b series said...throw it on and have fun.
Old Mar 20, 2009 | 07:14 AM
TheShodan's Avatar
Moderator
Ah, you simply have the Standard GT30R that most people are familiar with. The 56 trim.
http://www.turbobygarrett.com/turbob..._700382_12.htm
There is a tiny bit (hopefully you're not forcing it to make it have "play") of shaft play only because the oil is used to balance out the shaft during the 110,000rpm rotations that the turbo will see. They simply used a T4 divided housing (see sig).
Use a .035" sized-restrictor ONLY for the turbocharger , and please run the water lines.. Have fun!!
Old Mar 20, 2009 | 08:06 AM
Andy@AMR's Avatar
I thought the 30r came with a built in restrictor? Running a -3 line isn't enough? I didn't run a restrictor on my 35r, and it was just fine.
Old Mar 20, 2009 | 08:42 AM
TheShodan's Avatar
Moderator
It's built in, but for Honda applications that have a little higher than average oil pressure, using the .035" is fine. Many use this combination with results that have lasted for years.
Old Mar 20, 2009 | 10:51 AM
Mine is a 700382-12
I know about that number, but this is like that custom polished divided housing, so the numbers aren't there.
Whats the point of it being a t4 divided housing? compressor wheels still same size. Also water lines? doesn't mostly everyone run oil to it?
Old Mar 20, 2009 | 12:59 PM
morgan@synapse motorsport's Avatar
the gt series turbos need oil and coolant supplied to them. it should have 4 ports on the center section. 1 oil supply, 1 oil drain, and 2 coolant ports.
Old Mar 20, 2009 | 07:28 PM
he doesn't have coolant ports on his turbo. . . . . so its not a gt30r?
Old Mar 21, 2009 | 08:20 AM
TheShodan's Avatar
Moderator
A photo of this turbocharger at multiple angles at this point would be best.
Old Mar 23, 2009 | 12:31 PM
Here you go for more help.
Old Mar 23, 2009 | 01:10 PM
mangina's Avatar
ebay? not a 30r
Old Mar 23, 2009 | 01:13 PM
how so?
Old Mar 23, 2009 | 01:40 PM
mangina's Avatar
gt series turbos are watercooled. and ball bearing
Old Mar 24, 2009 | 01:10 AM
well, ok its not gt, but its t3/to4e , i think, anyone know what it is? 50 compressor and 63. turbine.
Old Mar 24, 2009 | 01:25 AM
SD_Lurker's Avatar
HT White Ops
Looks like an ebay turbo with a garrett comp housing on it. There is no badge that I can see in the center section. Also the exhaust housing looks like an ebay brand.
Old Mar 24, 2009 | 02:08 PM
how much do these go for?
Old Mar 24, 2009 | 03:18 PM
TheShodan's Avatar
Moderator
its not a common setup, so through up a number in the marketplace, and find out.
Old Mar 24, 2009 | 06:29 PM
so its not actual garret?
Old Mar 24, 2009 | 07:22 PM
SD_Lurker's Avatar
HT White Ops
No from the looks of it its not.
tig3rxiong
Aug 21, 2004 08:54 PM
booscivic
Dec 15, 2003 07:14 PM
JalopySiR
Feb 7, 2003 06:48 PM
4U2NV
Dec 29, 2002 11:06 AM
