How much power will stock rods hold?
My engine builder told me 500 hp but my tuner told me 400ish. im running 11lbs of boost at 350hp now.
thanks
thanks
I dont think your engine builder or tuner know much about the S2000, I woudnt go back. What size turbo and gas? Im on 7 pounds making 318...
http://www.youtube.com/watch?v=KUFFudEJnjk
garret t3/t04E is the turbo
precision 580cc injectors.... i know i will need bigger injectors. and i will get them depending on the amount of power i'll make.
Did you not watch that video? The internals are 100% STOCK. The guy has almost doubled 400 horse. You should start looking at bigger turbos. What is the AR on yours?
there have been countless people who have made well over 500 hp without any kind of engine trouble...these motors are very stout...you'd break your tranny or diff before the motor went out or you snap a rod
I had alot of trouble finding a turbo to fit my manifold. the turbo i had before got shot so i was stuck with the manifold. but its alright i don't need 700 horse. all im trying to do is get all i can out of the turbo without damaging anything. i do not have a stock motor mine is built with sleeves and pistons.
I am pretty confident in saying that you shouldn't be worrying yourself with your internals with your current setup, my only advise is to keep it filled with oil.
the rings landings are going to lose before the rods or the cylinder walls... rods and crank are pretty stout. but i tell you what let us know when you break your rods
Your engine builder sounds like a real big moron. CP or eagle rods wouldnt of been much more and worth it in the long run.
purposebuilt
Jun 26, 2019 06:30 AM
