300HP Build?
Old Jul 28, 2009 | 07:56 PM
Cole89ef's Avatar
Default 300HP Build?
I am looking to try and get 300hp out of my B16A. Recently rebuilt. No smoke, no cels, everything runs great.
I was wondering what I would need to make the engine reliable. Is a build necessary for this power goal? Will my stock fuel pump suffice? I am going to go with DSM injectors and probably a 43/48 volvo turbo.
Which ecu should I go with, I was going to get it tuned on Crome, and since I already have a PR3 I was wondering if that was chippable?
Thanks for everyone help!
Old Jul 29, 2009 | 03:07 AM
Schister66's Avatar
Man U FTW
Default Re: 300HP Build?
That sounds like an awfully small turbo to hit 300whp...also DSM 450s will barely cut it at that power goal. I would suggest at least a T3/T04e 50 trim .63ar for your goals.
Old Jul 29, 2009 | 05:08 AM
Cole89ef's Avatar
How is the stock engine for that power goal?
It actually is the Type R cam, throttle body and intake manifold.
Old Jul 29, 2009 | 05:47 AM
b20beast83's Avatar
stock engine will hold
Old Jul 29, 2009 | 06:36 AM
malink's Avatar
yep stock engine will hold no problem with good parts and a good tune. If I was you, I would run a pistons and rods combo and make more power. 300whp will be fun...for a month or so till you want more
Old Jul 29, 2009 | 08:15 AM
mike_s13_drift's Avatar
most people dont understand how fast 30hp is. my coupe has 349 and i see no reason for more power on the street. the b16 will love boost. get a good tune and have fun bro.
Old Jul 29, 2009 | 09:11 AM
malink's Avatar
well maybe its just me...you always end up wanting more.
Its like drugs
Old Jul 29, 2009 | 11:27 AM
b20beast83's Avatar
30hp is ***** slow man!
Old Jul 29, 2009 | 09:07 PM
Cole89ef's Avatar
Okay, after having taken out my friends friends 300HP turbo CRX, I have decided that I don't want to daily drive 300 FWHP...
I am going to go for a more conservative goal of 230-250, which I still think will be in the DD range.
What size turbo should I run on a stock-ish B16A, injectors, I just ordered a Drag Manifold today.
Does anyone know if the stock EF fuel pump will work for this, I am thinking DSM 450's for this setup.
Old Jul 30, 2009 | 09:00 AM
eg-gsr423's Avatar
should probably go with a walbro they're only like 100 and its worth the piece of mind.
Old Jul 30, 2009 | 11:38 AM
boostB4beauty's Avatar
as said above, dsm 450's will be working way too hard all the time with that sort of power goal. I would suggest at least 550's, or even 750's. If you decide to get 750's, at least you will not have to worry about changing them out again when you decide (and you will) to turn up the power.
t70accord
Oct 2, 2013 03:29 PM
MADBADGER
Honda S2000
20
Mar 21, 2009 12:41 PM
sfwdcrx
Nov 11, 2007 04:51 PM
YashiMotors
Sep 28, 2004 02:20 PM
