94 hatch starts than dies
Old Mar 19, 2009 | 07:49 PM
dannyn502's Avatar
Default 94 hatch starts than dies
Hi, my 94 civic hatch 146k miles starts than dies... i check and tested the fuel pump and i see the previous owner already changed it and working fine, also check the spark plugs, and fuse. I came to a conclusion of my injector might be dirty or needs changing. Can any 1 guide me through the cleaning process and changing? (i been messing with models 90 and below so im not very enlightened with injectors) OR does any 1 have a better expertise please dont hesitate to reply thank you.
Old Mar 19, 2009 | 07:56 PM
Nascarhatch's Avatar
Default Re: 94 hatch starts than dies
man its not hard to replace injectors at all. there is 3 10mm bolts that hold the fuel rail on, take them off and take off the fuel pressure regulator, it has 2 10mm bolts, then pull up on the fuel rail, some injectors may come with the rail but some may not. unplug then and clean or replace them, i would replace them cause im not sure that u can clean them without takeing them some where
Old Mar 20, 2009 | 07:23 AM
dannyn502's Avatar
ah thanks anyways nascar i found the problem i was to lazy and got no money to fix or clean the injectors so i recheck the fuel pump at day time and realize the previous owner change the pump but not the sock once i change that it started...and just to make sure i put some injection cleaner fluid in my gas tank then burn some gas...then for safe measures i just put in some octane gas just for the fawk of it lol ill try ur method of cleaning and changing if the problem continues. ty for the tip
slamedcivic
Nov 2, 2006 02:49 PM
90civSi
Jun 22, 2006 12:23 PM
92lsvteceg6
Nov 5, 2005 10:40 AM
Sinner
Jun 8, 2003 03:03 PM
Sinner
Jun 6, 2003 02:25 PM
