Integra LS cluster into 97 Civic DX.
Old Mar 19, 2009 | 03:36 PM
EFinawesomeman's Avatar
Default Integra LS cluster into 97 Civic DX.
I searched around and couldnt find anthing. Wondering if it is a straight plug and play with my factory speedometer cable. I have a tach-less cluster and don't want to necessarily want to install my big *** 5 inch tach. So can I just plug in the cluster? I'm good with wiring so if I need to re-pin thats fine. Just looks for an answer.
Old Mar 19, 2009 | 04:40 PM
trustdestruction's Avatar
Default Re: Integra LS cluster into 97 Civic DX.
It should be a direct re-pin with no added wiring involved. I'm not sure of what pins go where though.
Old Mar 19, 2009 | 04:43 PM
BlueIntegraBoy's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/94-97-98-01-integra-cluster-into-92-95-96-00-civic-wiring-diagrams-1053318/
Old Mar 19, 2009 | 05:50 PM
Thank you sir.
Old Mar 22, 2009 | 04:21 PM
jdmfanboi87's Avatar
hey guys, I got a question...well I have a gauge cluster from a 99 civic ex and I put it into my 97 dx and when I turned the car on the Tachometer was perfect but the speedometer starts off at 15-20mph and when I start driving the speedometer is stuck at 20mph and its jiggles but other than that it doesnt move....anyone know whats wrong?
Old Mar 22, 2009 | 04:23 PM
Don't hijack threads. Start your own, unless the thread is very relevant.
Your speedometer is messed up.
Old Mar 22, 2009 | 04:25 PM
I believe they used different speedometer gears for the 99-00. If you have a friend with a 99-00 ask if you can swap out speedometers for a minute to see if thats your problem.
This thread is daays old.
Old Mar 22, 2009 | 04:27 PM
It should still work though.
hondaracer76544
Honda Civic (2001 - 2005)
Nov 3, 2018 12:08 PM
OregonDucks
Oct 14, 2016 03:44 PM
foomashoo
Nov 23, 2004 08:56 AM
StreetRacinVejita
Oct 10, 2004 04:47 PM
