90 crx starting issues.
Old Mar 19, 2009 | 02:20 PM
All-Motor-Junkie's Avatar
Default 90 crx starting issues.
90 crx, not starting but turning over.
-Has fuel to fuel rail, injectors not spraying fuel. Checking pgmfi relay as i write this.
-All fuses are good.
Any ideas? Does anyone ave a link where to diagnose the main relay with a meter? thansk in advanced!
Old Mar 19, 2009 | 05:30 PM
scottmog's Avatar
Default Re: 90 crx starting issues.
just had that problem, main relay fixed it
Old Mar 19, 2009 | 05:56 PM
this is exactly what i though, and had a main relay that worked tested, same thing. Any other ideas?
Old Mar 19, 2009 | 09:03 PM
up up up main relay was NOT the problem.
Old Mar 19, 2009 | 09:13 PM
ERKK's Avatar
im havin the same problems man
Old Mar 19, 2009 | 09:30 PM
thisiskev's Avatar
maybe resistor box? though ive never heard of one going out before.
Old Mar 19, 2009 | 10:15 PM
I had tested that too, its not common that goes out. but its between the 5-7 ohms (OEM specs) of resistance. All my tools were stolen so i dont have a compression tester, im leaning towards compression now.
Old Mar 19, 2009 | 11:11 PM
up up up
Old Mar 20, 2009 | 04:45 PM
up up up any outside opinions?
Old Mar 20, 2009 | 05:24 PM
turbosivtec's Avatar
you should check if your getting any compression
Wazup
Dec 1, 2008 02:01 PM
ddubtoille
Nov 1, 2008 01:34 PM
Hugsnkisses01369
Aug 18, 2006 02:46 PM
hroosevelt
Jan 8, 2006 01:42 PM
gcajnr21
Sep 8, 2002 11:21 AM
