Where to buy plug (B) for AEM EMS?
Old Mar 19, 2009 | 01:57 AM
slowtegkauai's Avatar
Default Where to buy plug (B) for AEM EMS?
Hey, Im looking for plug B the one thats not used on the aem ems. I found a plug and pin kit but I dont need all those plugs. If someone can find just that one plug (B) please let me know where to get it. I have a 1020 AEM EMS.
Also, Im doing an LS VTEC and need to know where to connect the two wires from the vtec oil preesure sensor. Please help me out, thanks.
Old Mar 19, 2009 | 05:08 PM
mtber's Avatar
Default Re: Where to buy plug (B) for AEM EMS?
Contact AEM directly for the plug.
Concerning the wiring, refer to the pinout diagram for your 1020.
Old Mar 19, 2009 | 06:59 PM
Okay, thanks. I found out where they go BUTT. On the oil pressure sensor near the solenoid, theres two wires that come out of it. I know one side goes to the ECU (vtec oil pressure sensor) but where does the other wire go? Im thinking I need to ground that wire to the ECU. Any ideas?
Old Mar 19, 2009 | 08:21 PM
mtber's Avatar
Ground the other wire.
You don't have to wire vtec pressure switch with aem ems.
Old Mar 19, 2009 | 08:59 PM
ok. Is it safer to use the OPS? Does it matter what wire I ground?
Old Mar 19, 2009 | 09:33 PM
mtber's Avatar
Yes it matters what wire you ground.
Concerning the vtec pressure switch, it doesn't matter if you use it or not.
Old Mar 19, 2009 | 11:12 PM
Ok so what wire do i ground? Left (distributor side) or right (header side)?
Kprettyman
Oct 10, 2013 08:38 AM
$amGD3
15
Apr 14, 2010 05:53 PM
94EGKUSH
Mar 2, 2009 09:19 AM
crxtreme27
Aug 8, 2002 01:09 PM
