exhaust leak into cabin help
Old Mar 18, 2009 | 08:09 PM
dvlsfan30's Avatar
Default exhaust leak into cabin help
if the exhaust leak is coming into the drivers cabin where are the possibilities it may be coming from so i can look to see where the leak is.
im nt sure if its coming from the engine bay if possible or underneath. help so i can drive this thing lol
Old Mar 18, 2009 | 08:26 PM
fastrxu's Avatar
Default Re: exhaust leak into cabin help
the first rear disk swap i did I did't replace those rubber seals for the e-brake cables and I had exhaust coming in through there
Old Mar 19, 2009 | 03:09 PM
dvlsfan30's Avatar
bump
its not comin from the ebrake seal
Old Mar 22, 2009 | 06:25 PM
dvlsfan30's Avatar
bump again any help?
Old Mar 22, 2009 | 06:49 PM
jxhxb's Avatar
could be through your shifter??
have u replaced your shifter to a short shifter and taken off the rubber boot that divides the shifter and linkage? because before when i had a leak,even with mine on i think it comes through the shiftboot area from my headers connection to exhaust being loose
Old Mar 22, 2009 | 07:17 PM
dvlsfan30's Avatar
i have replaced the shifter with a short shifter a few years ago tho, i ordered a new exhaust coming tuesday so when i replace it hopefully it was the old exhaust that is causing thisr problem. maybe a gasket or a hole.
elmalouno
21
Sep 12, 2011 04:52 PM
cehcivic15
10
Jun 23, 2009 03:43 PM
KHowe
Jul 31, 2007 07:13 AM
Frost7177
Jan 17, 2007 09:29 AM
gobblebox59
Jun 7, 2004 06:17 AM
