Help me find a wideband WITHOUT a display
Old Mar 18, 2009 | 06:33 PM
cbustuner's Avatar
Default Help me find a wideband WITHOUT a display
I'm going the tunerview route on the new build and I want as few gauges as possible. I don't want to have a wideband display and have it displayed on the tunerview. What widebands are available without gauges,that can log through aftermarket engine management (ectune, neptune, hondata etc) and can at least be hooked up to a laptop for initail setup to make sure the afr matches in the wideband and the engine managment.
I honestly don't want an lc-1 unless I have to.
Old Mar 18, 2009 | 07:44 PM
93turbo16's Avatar
Default Re: Help me find a wideband WITHOUT a display
I use the LC1 and it works great. I am doing the exact setup you are thinking of doing. NepTune erpom with the LC1 logging through the ELD input and it logs displays through the tunerview II.
Old Mar 18, 2009 | 08:00 PM
cbustuner's Avatar
the only big issue I have with the lc1 is I don't want to do the wiring I guess. i remember the last time i looked into lc1 there were a bunch of grounds that needed done with a bunch of other wires,Are the newer ones like that or is there an easier way of hooking them up?
Old Mar 18, 2009 | 08:11 PM
93turbo16's Avatar
You still have a few grounds.. but you can put them all to the same point. It will work the same. I have mine all wired into my conversion harness. It is very easy to do.
Old Mar 18, 2009 | 08:26 PM
cbustuner's Avatar
I might look into that then. I usually wire the wideband up to the batter using a relay so that way the power and grounds come straight from the battery so that would be cool If I could use the lc1 like that? Are you an innovate dealer? I have bought a few ecu's from you in the past so if you are pm me some prices
Old Mar 19, 2009 | 09:02 AM
Rtype16's Avatar
AEM
http://aempower.com/ViewCategory.aspx?CategoryID=81
Old Mar 19, 2009 | 09:18 AM
DVDr's Avatar
The PLX can be had without the gauge . Descent unit.
Or you can build your own with DIY WB kits .
Old Mar 19, 2009 | 09:46 PM
Muckman's Avatar
Moderator in Chief
The original AEM UEGO didnt have a display. I had one and Hated it. I sold it as soon as AEM released the gauge model.
Old Mar 20, 2009 | 10:29 AM
cbustuner's Avatar
which plx? I found a plx that doesnt have a gauge (sm-afr) but I don't see anything about hooking up to a laptop or software.
I have a friend who might have a pre assembled techedge,so right now it's between the techedge or an lc1
Old Mar 20, 2009 | 11:26 AM
HRTuning's Avatar
The SM-AFR has an analog output which you connect to the ECU. Or you can connect to the serial stream to use their software I believe.
Old Mar 20, 2009 | 03:42 PM
mmuller's Avatar
Mad Scientist
zeitronix
Old Mar 21, 2009 | 05:25 PM
xenocron's Avatar
SM-AFR or the LC-1
Same basic no gauge and functions kit.
bLu92bUbbLe
Engine Management and Tuning
11
Aug 19, 2010 02:39 PM
turbob18si
Feb 23, 2009 02:00 PM
richieTN
Jan 16, 2007 04:19 PM
fullracegsr
Dec 10, 2003 12:23 AM
symba
Jan 22, 2003 06:10 AM
