obd0 type r possible
Old Mar 18, 2009 | 06:33 PM
88zchatch's Avatar
Default obd0 type r possible
I have a pw0 ecu running my b16 right now. I am putting a stock ITR motor in there and would like to know if anyone has ran an obd0 ITR successfully. Basically what I am wondering is it possible to put a stock ITR map on a chipped obd0 ECU
Thanks
Old Mar 18, 2009 | 09:31 PM
mtber's Avatar
Default Re: obd0 type r possible
If you insisted, you could tune an obd0 ecu using turboedit, zdyne etc to run a b18c1 using a obd0 b16 distributor.
Old Mar 18, 2009 | 10:00 PM
88zchatch's Avatar
I am getting my ECU chipped. I know BRE has the right editor for my ECU but after digging on pgmfi.org I cannot find a b18c1 or c5 map, not even close. All I want is an obd0 basemap that has stock ITR or "close" maps on it
Thanks BTW
Old Mar 18, 2009 | 10:31 PM
mtber's Avatar
Thanks BTW
You won't find a exact type-r b18c map. You will need to make your own starting on a pr3 map.
Old Mar 19, 2009 | 05:35 AM
mar778c's Avatar
Community Builder
Community Influencer
X2 agreed. I made 199 whp 135 ft-lbs using BRE. You should try to street tune 1st then dyno tune using a load control dyno.
Old Mar 19, 2009 | 10:29 PM
88zchatch's Avatar
Yeah I will street tune it I guess. Kinda wish I wouldn't have done a permanent install on my wideband in my turbo hatch.
Heres an interesting fact...I only live 40 miles away from the creator of BRE
Old Mar 20, 2009 | 10:27 AM
mar778c's Avatar
Community Builder
Nice, tell him to add a load depend vtec function and real numbers for scaling cranking fuel.
Old Mar 20, 2009 | 02:28 PM
88zchatch's Avatar
Those are some good numbers. What is your engine setup?
Old Mar 20, 2009 | 02:53 PM
mar778c's Avatar
Community Builder
The set-up is the thread below
https://honda-tech.com/forums/showth...583606&page=15
cory41
Dec 9, 2015 03:30 AM
kulo
Sep 17, 2012 02:35 PM
melloyellocrxgsr
Jul 20, 2008 03:59 PM
InJ3cted
Apr 25, 2005 06:57 PM
MidoriEK4
Jun 13, 2003 08:01 AM
