adjusting greddy type-s bov
Old Aug 12, 2002 | 11:24 PM
Trigun's Avatar
Default adjusting greddy type-s bov
ok so is this thing supposed to be open at idle or closed or halfway?
i recently tee'd the vacuum port for the bov off the brake booster line and i noticed that i never adjusted the bov before because it was sitting at the softest setting with the valve-thing wide open. well i tighten it a few notches till it closed and i drove around for a bit and damn, it whistled like MAD after i shifted. the whistle was louder than the blow off it seemed.
am i supposed to feel air out of the bov at idle cuz i don't feel anything
Old Aug 13, 2002 | 08:22 AM
Trigun's Avatar
Default Re: adjusting greddy type-s bov (Trigun)
bump .. help?
Old Aug 26, 2002 | 06:50 PM
pelotudo's Avatar
also interested...
Old Aug 26, 2002 | 08:25 PM
Trigun's Avatar
Default Re: adjusting greddy type-s bov (PeloTudo)
after playing around with it for a couple of days, i kinda figured it out. i adjusted it where it was totally closed at idle and kept driving and loosening it till i heard the perfect "whoosh ching" everyone was talking about it.
turned out that the setting was about 3/4 with the valve just a tiny, tiny bit opened during idle. basically, you just have to keep playing with the setting. hth
Old Aug 26, 2002 | 09:02 PM
TheIntegraGuy's Avatar
GReddy Type-S is the bomb! congrats on adjusting it!
Old Aug 26, 2002 | 09:06 PM
Ri5e's Avatar
Default Re: adjusting greddy type-s bov (SiDESLiDE240)
Mine stays open slightly at idle. You can feel air sucking in.
Old Aug 26, 2002 | 09:10 PM
Trigun's Avatar
Default Re: adjusting greddy type-s bov (BG Boost)
isn't that bad since the type-s doesn't have a filter? and if it stays open at idle, doesn't it stay open during all throttle positions also therefore leaking boost?
Old Aug 26, 2002 | 10:49 PM
It shouldnt matter if the BOV has a filter or not. Its mostly used for sound purposes. BOV's release air, not suck in air....and I'm sure considering the weight of the rock, it cant just jump in there...
Old Aug 26, 2002 | 11:01 PM
Trac226's Avatar
Mine is shut at idle, it takes a lil guess and check with that thing.
Old Aug 26, 2002 | 11:20 PM
1fstevo's Avatar
New User
Default Re: adjusting greddy type-s bov (Trac226)
Havn't you guys realize that if the BOV stay alittle open during idle, it also stay open alittle during throttle too, which means you are losing boost since it leak out of the BOV which also means you are pushing unfiltered air through the chargepipe and into the combustion chamber. Just a thought, Bov must be completely shut during idle.
Old Aug 27, 2002 | 08:19 AM
Trigun's Avatar
you were being sarcastic right?
Old Nov 30, 2002 | 02:19 PM
LOwrestling2001's Avatar
Default Re: adjusting greddy type-s bov ([Evo]Hybrid)
no, the valve is held open by vacuum, so when u go into boost the bov is shut. unless it is wayyyy too loose.
eg:R
Sep 17, 2006 06:47 PM
goofball123321
May 20, 2004 06:26 PM
_Endless_
Jul 4, 2003 10:56 AM
2K1NBGSR
Jun 19, 2002 02:50 PM
Aeka GSR
Jun 11, 2002 07:34 PM
