all you wire tuckin fellers!!
Old Mar 18, 2009 | 03:15 PM
93egboosted's Avatar
Default all you wire tuckin fellers!!
im doing a wire tuck on my car but i cant seem to find some sort of quick disconnect plug for where the harness will go back into the cab. help me out please
john
Old Mar 18, 2009 | 05:27 PM
Ya Digg's Avatar
Default Re: all you wire tuckin fellers!!
what harness? all of them I know have connectors. I think people cut and solder all the wires any way and make some longer too so im pretty sure they have to be cut.
Old Mar 18, 2009 | 05:44 PM
im running all of my wires into the cab through the stock hole where the heater core lines used to be. my problem is i cant seem to come up with a way to seal the hole but still have is accesible when i have to unplug the harness. im looking for some kind of plug along the lines of this. http://cgi.ebay.com/ws/eBayISAPI.dll...m=350166004425
as you see that plug can be attached on the firewall and go inside the cab, but on the other side i can attach my wires onto it and its on plug and be accesible
Old Mar 18, 2009 | 05:45 PM
SOHCinWA's Avatar
ChaseBays FTW... He can get you set right.
Old Mar 18, 2009 | 05:50 PM
tunerfreak87's Avatar
New User
Yeah, just be careful if you're gonna cut the wires and re-solder them to extend...had a buddy who did a complete wire tuck like that and 3 weeks later had lights going out lol. Good luck with it.
Old Mar 18, 2009 | 06:00 PM
EFinawesomeman's Avatar
If your talking your engine harness, most people take the harness out and re-loom it and drill a whole in the firewall where it wont be visible. PM someone like Chase or RyWire that make these types of Mil-Spec harnesses.
Old Mar 18, 2009 | 06:54 PM
https://honda-tech.com/forums/appearance-build-threads-122/93-hatch-build-2501178/
thats my build if you scroll down you can see what ive done so far with the harness and where the harness goes into the cab i dont want it like that so i need so kind of connector. ive seen a couple builds with what im looking for but i cant find them.
Old Mar 18, 2009 | 07:27 PM
Just figure out what wires you need to get connected and get the Mil-spec connector that has the amount of leads you need buy that and should be easy after that.
CRwreckz
Jan 4, 2008 07:17 PM
jwbnavy
Dec 4, 2007 02:20 PM
TeamDOHCside
Dec 25, 2003 09:46 PM
Jonathan_ED3
Jun 21, 2003 04:16 PM
