93 hatch build
Old Feb 15, 2009 | 12:55 PM
93egboosted's Avatar
Default 93 hatch build
my name is john and this is my first honda build. i used to have a few dsm's but they got old after a while. i bought my hatch about 2 years ago and been daily driving it, but now its time to start building it. ive researched alot and have a pretty good idea what i want. the first thing im doing is all the suspension work brake line tuck, and wire harness tuck which you will see in the following pictures.
parts i have
integra front and rear brakes, 4040, master cylinder, booster
tein springs
tokico struts
asr rear subframe brace and sway bar(on order)
energy suspension bushing kit and they say its a "master kit" but it really isnt
for the engine im shooting for around 425-450 horse.
parts i have
b16 head
ls block
arp head studs
golden eagle vtec kit
fidanza flywheel
hondata s200
heres a few pics of some of the parts i have and the progress that ive made so far
Old Feb 15, 2009 | 12:59 PM
Default Re: 93 hatch build
heres some pics of the car and also a pic of my 00 si
let me kno what you all think
Old Feb 18, 2009 | 09:35 AM
Diller's Avatar
Nice start! It looks like your going for an lsvtec. Should be a pretty quick car. Are you going with a NA or FI build?
Old Feb 18, 2009 | 10:59 AM
American.Graffiti's Avatar
Good luck with your build. Remember NA>*
Old Feb 18, 2009 | 11:44 AM
pingar's Avatar
Originally Posted by diller
nice start! It looks like your going for an lsvtec. Should be a pretty quick car. Are you going with a na or fi build?
+1
Old Feb 18, 2009 | 11:48 AM
ALLxMOTOR EG's Avatar
Vietnamese!
Nice,keep it coming!
Old Feb 18, 2009 | 01:04 PM
yea ls vtec turbo. https://honda-tech.com/forums/forced-induction-16/engine-build-ls-vtec-sc61-2501801/ thats my list on my engine build. i used to have a couple dsm's and theres nothing like boost. i have a high comp ls v in my si rite now but... i miss boost. slowly but shearly im making progress. waiting for my buddy to bring over his air powered brake bleeder so i can drain the system and complete the brake line tuck. but ill keep everyone posted on my progress
p.s. si is forsale with out engine trans
john
Old Feb 18, 2009 | 01:05 PM
lol o yea i sold the stock d15 and trans for $325 you think it was a good deal?
Old Mar 3, 2009 | 01:22 PM
made some progress this weekend on the wire harness. i bolted up a mock engine and bolted it in and lenthened the harness where i needed to. im having second thoughts on how im sticking the harness through the firewall. 1) because i cant figure out how to seal the hole. 2) making it disconnectable easliy.
Old Mar 3, 2009 | 01:25 PM
i also ordered wire sheathing to wrap the harness in from wirecare.com
Old Mar 10, 2009 | 02:42 PM
pressed out the old bushings,painted the control arms and sway bar. sprayed my first coat of undercoat in the wheel wells. got my new prothane trailing arm bushings prolly going to get new front wheel bearings next week and go over my buddies house to use his press to finish the suspension. got my arp wheel studs but i ordered stock size and i wanted extended so i got to return them. also got my new wire loom. stay tuned!!
Old Mar 18, 2009 | 07:44 AM
got some more work done, pressed in all new bushings and started putting everything back together. finally got my asr subframe brace and sway bar in. also made a plate to cover up the heater controls.
Old Mar 18, 2009 | 07:45 AM
also got new wheel bearings and tie rod ends
Old Mar 18, 2009 | 09:46 AM
r_Senik's Avatar
nice...hope u are keepin it captive blue
Old Mar 18, 2009 | 02:45 PM
yea... ive thought about painting it white, black, red. but i am going to stick with the original color, because im not puting a carpet back in it so i didnt really want to rip everything out plus i do like the color i havent seen that many of them in that color
Old Mar 18, 2009 | 05:14 PM
brandonEM1's Avatar
gl with the build
Old Feb 1, 2010 | 05:27 PM
hey havent posted on my build ina while ran into money issues but anyways ive some progress done on the car. Decided not to do a brake line tuck or wire tuck figured its not going to be show car so screw it. i got the bay pretty much back to stock execpt a few things.
sent my ls block out to the machine shop with cp 9.1 81.5mm pistons, eagle rods getting it bored honed and balanced.
parts i got since ive last posted, also progress done on the car.
tial 44mm wastegate
afi ramhorn
tial 50mm bov
victor x mani
blox 76mm tb
precision 1000cc injectors
golden eagle fuel rail
hollman boost controller
autometer boost and oil gauge
innovate wideband
haha check out my custom door panels
more to come!!! let me know wut u guys think
john
Old Feb 2, 2010 | 06:37 AM
MLRtime's Avatar
in for updates!
Old Feb 10, 2010 | 05:48 PM
ive been determining which turbo i want to use on my car im shooting for around 400-450 whp, im looking into a holset hx35w which will be a pretty good turbo from what ive read. also they pretty cheap, i work at a diesel shop where we rebuild and put together engines for generators, pumps, etc. a guy i work with was looking around the building the other day and found a old core engine with a hx35w so im going to see if the owner will sell it. anyways just got my trans its a 01 gsr i took the case off it and and looks very good the reverse gear is a little ground down but i think thats normal. also bought a intercooler and had the welder at work weld some threaded tabs and mounted her up!
Old Feb 11, 2010 | 10:12 AM
benjamin626's Avatar
looking good so far playa.
Old Feb 11, 2010 | 10:23 AM
SouLaQuaRiuS's Avatar
nice suspension work! build is looking good!
Old Feb 11, 2010 | 01:40 PM
javi dc2's Avatar
New User
dam thats sweet
Old Feb 11, 2010 | 04:05 PM
thanks. yea it finally starting to come along. the guy that i sent my lower end to is kind of dicking me around havent talked to him ina bout 3 weeks.... but hopefully updates sooooooon!!
john
Old Feb 16, 2010 | 08:02 AM
DM540's Avatar
sweet build! Good Luck!!
Old Feb 16, 2010 | 09:41 AM
DrZFiNeSt's Avatar
Nice build
balliso911
Jun 17, 2012 09:15 AM
hybrid1990crx
Aug 19, 2007 06:44 AM
FakeJDMEF8
Jul 31, 2005 02:31 PM
afxtwin
Dec 20, 2004 07:16 PM
DragII
Jun 27, 2001 05:46 AM
