just got 88ef wiring harness ?
hey i just got an 88 ef and i have a 99 sohc vtec motor wat do i have to do to run this motor with my wiring harness, i have an str-4 and this is my first hinda so this all foriegn language to me right now would it be easyer to jsut run a 99 wiring harness with 99 guage cluster, is that possible? or would that be more expensive
ok, the harness needs to be multi point fuel inejection, meaning four injectors instead of two, you will need the harness to have a vtec solenoid plug if it doesn't have it already, the tranny needs to be a cable tranny, but hasport makes a hydro kit for efs but thats only for b series correct me if im wrong, you will need a obd-1 conversion harness if its obd2 then you get the point, also what ever oyou will need a obd dizzy adapter plug also ummm i think thats about it anything else?
now could i just instead get the wiring harness out of the 99 civic my motor came out of and use the 99 guage cluster or will that not work with the ef lighting or watever wouldnt match up?
umm in order to use the cluster would be something else entirerly its not a striaght plug AND play, the harness from a 99 will NOT work but this one will talk to him about custumizing it for a vtec he will hook you uphttp://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=190294556417&ssPageNam e=MERC_VIC_RCRX_Pr4_PcY_BIN_IT&refitem=19029009526 5&itemcount=4&refwidgetloc=closed_view_item&usedru le1=CrossSell_LogicX&refwidgettype=cross_promot_wi dget&_trksid=p284.m183&_trkparms=algo%3DCRX%26its% 3DS%252BI%26itu%3DUCI%252BSI%26otn%3D4
no mine is still dual point got my taxes back looking to do a b series swap now
yes it should mount up to the mounts you already have i could be wrong but im almost positvie they will
ok so i guess im gonna get a cbale tranny and sell my hydro since it seems way easier will that make a difference in the ecu or wiring harness at all will the axles fit and will the cable tranny bolt up to a 99 d16
ok so i was told by the state referee that if i want to run an ob2 99 sohc vtec motor i just have to have all the equipment from that motor ecu ect. so i if i buy a harness thats been converted to mpfi and with all the correct hookups and all for the vtec will that run the same as if i just had a 99 wiring harness in there as far as the smog numbers go
HuggerHatch
Jul 31, 2005 10:36 PM
