How do you guys arrange you piston ring endgaps
Old Mar 17, 2009 | 12:30 PM
averyvm's Avatar
Default How do you guys arrange you piston ring endgaps
Hey what up HT,
Im not really satisfied with the compression on my freshly rebuilt LS and I want to put in some new rings and and head gasket. When I rebuilt the motor I used the arrangement below. Instead doing the samething over again and expecting the same results, I want to try something different that will garentee good compression. So how do you guys arrange your piston rings.
-Avery
Old Mar 17, 2009 | 12:48 PM
TurdBlown Teg's Avatar
Default Re: How do you guys arrange you piston ring endgaps
well what is your compression in the first place?
then go from there
Old Mar 17, 2009 | 02:08 PM
4g hatch's Avatar
i agree. what head,pistons do you have also?
Old Mar 17, 2009 | 07:10 PM
M3_4_Me's Avatar
New User
that looks just like how i did my d15...exactly how the haynes manual said to do it lol
Old Mar 17, 2009 | 08:40 PM
averyvm's Avatar
Oh well I did a compression test today and they were all around 195psi which was kind of high. But it seems that I have been getting different results with different testers. But it completly stock LS motor with stock pistons and head
Old Mar 17, 2009 | 08:53 PM
4g hatch's Avatar
thats good for stock ls pistons. you will get different results with different gauges. the #'s need to be within 10% of each other
Old Mar 17, 2009 | 09:02 PM
averyvm's Avatar
oh ok thanks. the numbers were pretty consistant across the board
Old Mar 18, 2009 | 05:31 AM
mmuller's Avatar
Mad Scientist
this is how i do
http://www.theoldone.com/articles/en...istonfacts.htm
Old Mar 19, 2009 | 01:47 PM
at 195 dont expect much more from the 9:1 pistons or the 9:3 that are in there.
Old Mar 19, 2009 | 02:11 PM
Lubo_25's Avatar
dynamic compression, gauge quality, removing spark plugs from cylinders, and weather all play a part in your readings but for your compression ratio and motor type the numbers are looking great for the low comp. pistons that are in there as long as they're within 5% of each other and you used honda's ring orientation nothing else matters...now go and seat the rings...
cheers
Lubo
kpjo4
Jan 8, 2010 07:38 PM
batboyvaj
May 1, 2007 09:10 AM
B18 CYA
11
Jul 28, 2006 06:24 PM
junkyard racer
Oct 31, 2004 05:32 PM
accord19
Feb 23, 2004 04:30 AM
