Civic will not run
Old Mar 16, 2009 | 02:09 PM
SIC_WIT_IT's Avatar
Icon2 Civic will not run
i did a tune up, replaced the main relay, replaced the ignition control module in the distributor, new cap and rotor,but this car will not stay running..it will start up butafter a 10-15min drive the rpms go haywire and the car shuts off. if you wait a few minutes it will start but you cant go very far before it does it again.
FYI: when i replaced the icm i noticed a considerable amout of oil inside the distributor because of the gasket was cracked.
i want other ideas on what might be wrong before i go and get another distributor..
Old Mar 16, 2009 | 02:44 PM
robbys89's Avatar
Default Re: Civic will not run
check your MAP and TPS sensor. it sounds like its defo something electrical
Old Mar 28, 2009 | 05:38 AM
SIC_WIT_IT's Avatar
****UPDATE**** When the car shut of this time i took the number one plug wire out and put a screwdriver in to see if i had any spark...well it didnt...so is it the distributor? i've already changed the icm and ignition coil
Old Mar 28, 2009 | 12:54 PM
Tate in action's Avatar
try another ecu
Old Mar 28, 2009 | 01:46 PM
Former User's Avatar
Is the CEL ON?
Thecargoddess
Jul 3, 2024 07:09 PM
kingnothingftw
Mar 17, 2015 03:30 PM
xkrntamax
Mar 23, 2007 10:14 AM
AmginE
Feb 27, 2004 02:17 PM
psicrxsi
Sep 28, 2003 10:36 PM
