DA Rear Sway bar on EF
Old Mar 16, 2009 | 12:19 PM
88 EF Hatch's Avatar
Default DA Rear Sway bar on EF
So what exactly does the DA sway bar do to your car? I recently swapped rear trailing arms and control arms and struts off DA onto my ef, but have not done sway bar. What is its purpose and is it an easy bolt on?
Old Mar 16, 2009 | 12:26 PM
sgallagher's Avatar
Default Re: DA Rear Sway bar on EF
If your car has the body nuts already welded into the body it is an easy bolt on.
A rear sway bar will help your car rotate more, or help counter understeer. You can basically get the same effect by removing your front sway bar.
Old Mar 16, 2009 | 12:30 PM
so front sway bar is bad and rear is good? huh? and what is understeer?
Old Mar 16, 2009 | 12:42 PM
jdmed3's Avatar
lawlz well if you have the mind and money then both sway bars would be great if you use a honda for its true purpose (which isnt going in a straight line the whole time FYI)
Old Mar 16, 2009 | 12:46 PM
so does my EF already have a front sway bar? or do I take that off the DA? I have a DA at home for parts so I am using it all. If Ef does have sway bar is the DA a better one and is it an easy bolt on. Let me know
Old Mar 16, 2009 | 03:26 PM
ZC DOHC CRX's Avatar
is there any advantage with the DA sway bar over the CRX SI sway bar?
Old Mar 17, 2009 | 08:34 AM
Idk
Old Mar 17, 2009 | 10:22 AM
tkda's Avatar
the DA rear sway bar is 14 mm from the 2 door, 15 mm from the 4 door. and an si has a 13 i belive.
i would get an hf front sway and a da 4 door rear sway.
the hf bar in front is 15 i belive? i know its smaller than any other ef.
you know in the auto cross pictures when the car is on three wheels, thats because they have a huge rear sway.
Old Mar 17, 2009 | 10:23 AM
tkda's Avatar
o and the DA front bar is 22 mm.
Old Mar 17, 2009 | 10:25 AM
so smaller better or bigger better?
Old Mar 17, 2009 | 10:46 AM
faster Type R's Avatar
because our hondas are prone to understeer because they are FF cars...a larger rear sway bar will help counter the understeer. a small front sway bar will do the same...usually people get larger rear sway bars.
Old Mar 17, 2009 | 10:55 AM
so large rear and small front is the best?
Old Mar 17, 2009 | 07:47 PM
tkda's Avatar
pretty much the ideal set up. but it depends on what you are doing with your car.
for install you need si lca's and you need to make some brakets that you bolt the sway bar to; through bushings.
Worth it though.
search': dx sway bar honda tech- on google.
their is a good right up on makiing your brakets and install of a da sway bar.
Old Mar 17, 2009 | 08:04 PM
ninty1civic's Avatar
my buddy has a 91 crx with suspension techiniques front and rear sway bar and i put it up on thre wheels coming out of my drive way, it has a real steap like ramp up, so i ride up it crooked so slammed cars dont scrape mufflers an ****, and that was the result lol
Old Apr 10, 2009 | 04:20 PM
rival12's Avatar
Any idea which bolts fit? I removed all the Hardware from an '91 SI Civic.
I just finished installing a Tanabe Rear Sway, which I must be so lucky cause it barely fits around the custom exhaust......
Anyways, i've got everything in place bolted up, except the mounting brackets.
The nuts are welded into my DX Civic, however, the bolts i took off the SI, seem a tad bit larger......can't say what size they are, other than the fact that they tighten with a 14mm Socket.
Any ideas?
Old Apr 10, 2009 | 04:47 PM
Tyson's Avatar
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/how-i-put-da-rear-sway-bar-my-dx-hatch-pics-galore-1146145/
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/sway-bar-sizes-1894834/
Old Apr 16, 2009 | 02:26 PM
rival12's Avatar
yeah those threads didn't help, but thanks anyways i guess.
Old Apr 16, 2009 | 04:17 PM
Tyson's Avatar
well it clearly answered HOW to put it on.
the purpose of a swaybar is just to add lateral stiffness to the spring rate of the vehicle.
Old Apr 18, 2009 | 02:04 AM
rival12's Avatar
Yeah, I wasn't asking how to put it on, as everything is connected except for the mounting brackets.....
I asked for the size of the bolt that would fit to tighten the brackets to the frame...
i.e. I have everything, and the bolts are slightly too big......i don't need custom brackets, as i already have the factory brackets, that line up to factory holes.
Old Apr 18, 2009 | 06:51 AM
Tyson's Avatar
M8x1.25
Old May 3, 2009 | 01:12 PM
rival12's Avatar
After scraping off some rust, i found that there were threads in the frame.....although stubborn, some wd40, and power tools got them in.
GameBoyeas
Apr 20, 2018 10:56 AM
Ed7touge
Mar 19, 2011 08:15 PM
thehatchninja
Oct 11, 2006 01:29 PM
SloA$$ DA
17
Jun 8, 2006 08:52 AM
fireant
14
Apr 12, 2006 11:43 AM
