ASR Subframe Brace Compatible W/ ST Rear Sway Bar - Honda-Tech - Honda Forum Discussion
Old 04-17-2018, 08:00 AM
GameBoyeas's Avatar
Default ASR Subframe Brace Compatible W/ ST Rear Sway Bar
Hello all,
I recently purchased a "Suspension Techniques Rear Sway Bar" for my 1990 Honda Civic EF, I was looking into purchasing an "ASR Rear Sub-Frame Brace" as I've noticed when the EF's are track raced they tend to have rear sub frame tear out, especially when a larger than OEM sway bar is installed.
Could someone tell me if there will be any interference when installing this brace? Preferably someone that has the combination already.
Thanks,
Nick
GameBoyeas is offline
Old 04-17-2018, 09:42 AM
Tyson's Avatar
Default Re: ASR Subframe Brace Compatible W/ ST Rear Sway Bar
asr wont help with the kind of rear subframe tear out that happens on EFs. its totally different than EG/EK/DC due to the way the sway is mounted.
in other words, the ASR brace is a boat anchor on an EF.
tear out happens on an EF because of using sticky race tires. not the swaybar. the tear is at the top of the subframe.
Tyson is offline
Old 04-19-2018, 04:24 AM
Doesn't the ST sway bar come with chassis mounts already to suit? You could probably run the ST sway bar on the ASR brace but it'd imagine the endlinks might not line up to the LCA.
Grifty is offline
Old 04-19-2018, 07:33 AM
Creator's Avatar
Never heard of this being a problem with EFs. With DCs it's a known issue. I'm guessing you might get more of a response if you post this under the road race thread.
Creator is offline
Old 04-19-2018, 08:02 AM
It does, it mounts up really well but mine rubs my exhaust. Been thinking of taking it off and running the stocker as I don't really need a rear sway.
kraquepype is offline
Old 04-20-2018, 05:00 AM
Great info, didn't think it would line up well.
Grifty is offline
Old 04-20-2018, 10:56 AM
Oh sorry, I was talking about using the mounts that come with the ST sway. Don't know how it would work with the ASR brace.
theguy22
Suspension & Brakes
13
08-19-2018 08:02 PM
Coopa B18c5
02-04-2013 07:23 PM
Hatchorama
11-08-2009 05:32 PM
bobmugen
Northern California (Sales)
14
03-30-2009 03:11 PM
Quick Reply: ASR Subframe Brace Compatible W/ ST Rear Sway Bar
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
Question Title:
Description:
