Iacv? help please
Old Mar 16, 2009 | 10:21 AM
JDM-sol 89's Avatar
Default Iacv? help please
Just finished my buddies swap and its throwing a 14(idler air control valve). It never threw a code before the swap and we swapped in the same motor. The car is a 99 dx hatch with a obd2 gsr swap, converted to obd1, the only thing that is different between the two motors is the new one we sapped in has cp 9:1 pistons and eagle rods. It is turbocharged and it has a tune for 5 pounds, we just wanted to get the cel squared away before we get it tuned fo 20.. Any help is greatly appreciated.
Old Mar 16, 2009 | 11:13 AM
Since 1983's Avatar
Default Re: Iacv? help please
clean the IACV and see if it does anything.
Old Mar 16, 2009 | 05:41 PM
JDM-sol 89's Avatar
That couldnt be it though because it ran and idle perfectly before the swap. I was thinking we may have gotten some of the vaccum lines routed incorrectly. Im trying to find a diagram for how the hoses are routed.
Old Mar 16, 2009 | 05:49 PM
muasboi's Avatar
its very common to have switched the iacv plug with another valve. i forgot which one, but back there, there are 3 rounds plugs that plug into 3 different sensors. switch them around and see it that helps.
Old Mar 16, 2009 | 06:08 PM
joelmatt89's Avatar
purge solenoid, iat, and iacv all have the same plug but it is unlikely you would switch them although it is possible. First check the wiring to the iacv from the ecu etc.
Old Mar 19, 2009 | 07:47 PM
JDM-sol 89's Avatar
Well i found the wiring diagram in the chilton book and everythings wired up correctly, swapped out the whole iacv with a good one and still throws a code. maybe wiring? anyway to check if the wires are bad?
Old Mar 19, 2009 | 08:14 PM
hatchnideas's Avatar
did you do the proper three wire to one wire iacv fix? i swapped plugs and all that, but i still got a cell. turns out i had to repin the engine harness plug that plugged into the ecu conversion harness because the ecu harness i had, apparently, didnt account for it.
Old Mar 19, 2009 | 08:16 PM
raidacaipo's Avatar
switch the Iat wire plug with the IACV.. they both look the same.. I beleive the IAT is a red/orange wire color..
Old Mar 19, 2009 | 08:23 PM
Nascarhatch's Avatar
i threw the same code it was the wires to the ecu were pulled out i hade to repin them wasnt hard at all
Old Mar 20, 2009 | 06:27 AM
JDM-sol 89's Avatar
ok i will check the pins. and the other iacv we used came right off my buddys running gsr [obd2]. Cant you use a voltameter to see if the plugs are getting power?
latinracerct
Dec 6, 2006 01:24 AM
HYBRIDHATCH92
Dec 18, 2004 08:00 AM
jdm civic 2000
Aug 27, 2004 05:31 PM
CTL
Mar 3, 2004 05:22 PM
tysf
11
Jul 28, 2003 10:57 PM
