Time for my H23 VTEC Build DD
so I have finally been researching and looking and have finally got 99% percent of my parts and decided I want to start my build. it was a present to myself for getting out the army after 6 yrs.i was going to do an h22 build but my engine builder said why not try to do h23 vtec and and see what you can do out of it. so i said f--- it lets get this going. my goal is 240-250 and 190 tq. i will see what happens.its going into my 4th gen prelude sivtec. possible compression is going to be 12.5 to 1 on 93 octane.
head
h22a (hot street package from CCCYLINDERHEADS
euro r im port match to the tb ( ROSKO built)
rdx injectors with fuel rail (from ROSKO also)
crower stage 3 cams
sk2 adjustable cam gears
titatitum springs + retainers (JGE)
flat valves (JGE)
68mm tb (s2000 style)
walboro fuel pump
arp head bolts
block
h23a1 block
h23a1 crank balanced and polished
h23a1 rods
type s pistons std
honda oem pistons rings
acl bearings
11.5 lb flywheel (lsd motorsports)
6 sprung street strip clutch kit (lsd motorsports)
new oem water pump
new oem oil pump
balance shaft elimantor kit (kaizenspeed)
manual tensioner replacement kit
honda oem belts
bisimoto custom header (on the way last part missing)
oem honda head gasket
tranny
h22a
obx lsd tranny
stock gear ratio i drive on the highways alot so need some driveability.
dss axles level 1
I should be getting my head back from steve sometime this week or next. would have been earlier but poor guy got a flu. i am probably going to go to xenocron for tuning ectune most likely. getting the block cleaned at the machine shop should be here next week. hopefully I can be ready for honda day in april but will be close. I will have pics soon next couple of days hopefully!!! let me know what you guys think! the reason for people names in caps is thanking them for all the help they have given me...!!!!!!! and yes i know its in prelude section but wanted all motor opinion also.
V.2
https://honda-tech.com/forums/showth...525420&page=13
New chassis V.3
https://honda-tech.com/forums/showth...5#post49544375
head
crower stage 3 cams
flat valves (JGE)
walboro fuel pump
arp head bolts
block
h23a1 block
h23a1 rods
type s pistons std
acl bearings
new oem water pump
new oem oil pump
honda oem belts
tranny
h22a
obx lsd tranny
dss axles level 1
V.2
New chassis V.3
wow it shows how much of a help you are. do me a favor and go somewhere else with that attitude help honda-tech not hurt it.
and ... ACTION!
To be perfectly honest the way the title was typed I was very hesitant to visit this thread then you say things like that that make you appear rude, ignorant, class conscious and like a punk kid.
If you don't like what someone says then ignore them, otherwise your build thread will degenerate into a locked, useless POS.
Good luck with the build.
i thought i would be a little different but i guess that was wrong i ask moderator to fix it when they can
thanks i am just hoping it puts down me down into possible low 13's and maybe hit 12's
took some quick pics but camera acted up
i will its just bisi is a little back up with headers right now so while i wait i will break in the motor and then when i get the header take it to the dyno
you will love the graph around 5500 rpm. Just wait. Its going to be a power where you sit in 2nd and punch the gas at 4000 with traction and then the tires break lose around 5500.
fun ****.
fun ****.
got pics of some parts. i just fun out that the block is good to go and i should be picking it up in a few days. crank was balanced and block was cleaned and leveled. the pistons where taken care off into the rods. hopefully i get the head this week cause i want to start putting all the stuff together.what sucks is that when i was putting the mainfold together i am missing a freaking rdx clip and i don't know where it is. i've seen that u can use the scion mod but i was seeing if anyone knows where i can get the clip?????? it sucks that i have all this stuff and nowi missing a freaking clip.
the only good thing this week was that i was able to get some high grade steel braid hose from my job that we are getting rid off. since i work on helicopters we have a good amount of it left and its good for 1500 psi just buy fittings for the proper spots still wondering if i should do a catch can???
for me the reason was i want to use the h23 block instead of the h22. the manual tensioner comes in that block and most of the squirters are there just have to slightly readjust them so your crank willn't starv from no oil. also i the h22 block walls where not as good as the h23 block. thats my reason behind it. but most diffenetly wanted the tq.
You mean the fuel rail he listed in his parts list, then posted pictures of?
Xenocron sells the injector clips with the top hat adapter, I'd guess you could talk him into selling the clip alone
