96-98 climate control help!
Old Mar 15, 2009 | 05:06 PM
ntoxicatedtigah's Avatar
Default 96-98 climate control help!
OMFG i've been searching all over, how do i just take out the climate control so i can switch out my audio deck. fck! i'm thinking its just clips but i dont wanna **** up and have that **** falling out all the time.
help please.
thanks
Old Mar 15, 2009 | 06:14 PM
thetunersource's Avatar
Default Re: 96-98 climate control help!
HAHA. Man calm down. You pop out the climate control by carefully pulling at the edges, make sure you don't pry it out and really crack it.
Old Mar 15, 2009 | 11:24 PM
gsr1379's Avatar
screw behind the Hazard switch and behind the defroster and two on the bottom underneath you need to remove the Ashtray cig lighter thing and it should pop off. Im pretty sure that is all the screws I just did this the other day.
Old Mar 15, 2009 | 11:37 PM
teamworxek9's Avatar
nope, there are six screws the ones mentioned and two more in the worst of places. i removed all the lower plastics to get at the middle screws just do that and look up to where you would never put screws with a flashlight and youll find them.
Old Mar 16, 2009 | 06:58 AM
wtf i can't seem to find out diagram of this **** anywhere, anways all this just to pull out my audio deck?! FACK! dang doode. so its not as easy as the first guy makes it sound. and if gsr1379 your correct then the hazar and defrost switch pops out , and you'll see the screws?.
Old Mar 16, 2009 | 07:39 AM
dad0c402's Avatar
be careful when removing those two switches, you can mess up the edges really easy. Use a wide flat head or something similar. It's only hard, the first time you do it. Once done it's not really that hard.
Old Mar 16, 2009 | 07:40 AM
DC2-ProdUcTiOnS's Avatar
From: Howcome we park on driveways, and drive on parkways?
theres the info on how i removed mine on the first page of instructions...
https://honda-tech.com/forums/showth...2500737&page=3
Old Mar 16, 2009 | 07:56 AM
ok , so all i need to do is those 2 screws out i'm good? i'm only taking that panel out not the whole damn center piece. its cuz i looked at my deck, and it won't slide right out or anything, fudgsicle.
Old Mar 16, 2009 | 08:01 AM
You kinda have to remove the whole center unit...There are 4 screws holding in the climate control from the back of the unit. If you look on page 2 of my thread i took close up pics of the climate control, you can see the holes where the screws go to hold it in. You MAY be able to take the screws out, and pull the whole center unit out enough to be able to get a screwdriver back there to get them out. IMHO though its not that hard at all to get it all out, if you have an aftermarket deck, that should be one of the easiest things to remove on this project...
Old Mar 16, 2009 | 08:06 AM
actually...now that im looking at it, the pics on page 2 wont help....there too close...
BUT
heres what you can do, if you remove the lower dashboard cover (the piece right beneath the climate control unit) you can get to the screws....here look....
heres what the back looks like....you can see the two screws, one on top of the other on the right side...its the same on the left...
to get at them....remove this....
Now if you get on your back under the dash, you should be bale to see each side, like this...
hope this helps....lmk
Dc2
Old Mar 16, 2009 | 08:14 AM
yeah man i hope it will too. thanks alot for your help. and i do have aftermarket deck.
Old Mar 16, 2009 | 08:16 AM
well i haven't explain to anyone, basically, my deck worked fine, but all the sudden the power keeps going out. i thought it had to do with battery i was wrong, so if i put pressure on my climate control upwards a little bit, the deck power stays on. i'm guessing the wiring back there , something is loose. thats why i gotta do all this. it sucks driving without listening to my TRANCE! SHIZA! makes me cranky. (o_O) (^_^) (^_~) (>_<)
TEAM EoR
Apr 12, 2008 11:26 AM
bavarian06
May 21, 2006 01:40 AM
halozero
Oct 6, 2005 09:24 AM
ner0x
Jun 23, 2005 07:17 PM
teg92
10
Mar 6, 2005 10:51 PM
