suspension
Old Aug 12, 2002 | 05:55 PM
AZcivicHeat's Avatar
Default suspension
I wanna put stock GS-R LCA's with springs and struts in my 93 civic. Has anybody done this and had problems or praise? Also need to find those items in fairly good condition.Thanks
Old Aug 14, 2002 | 06:05 PM
Pazzio1's Avatar
Default Re: suspension (AZcivicHeat)
Very simple operation...a nut and bolt job. The springs are a bit stiffer since they have a higher springrate for the 'B' engine. Also, if it's the rear suspension you are talking about, you can add on the rear sway bar with little modification to the chassis mounts.
Old Aug 14, 2002 | 06:26 PM
Default Re: suspension (Pazzio1)
So could i put on an aftermarket sway bar built for the GS-R or only the stock one?
Old Aug 14, 2002 | 07:44 PM
Civic1992DX's Avatar
prepare to have you Civic beigh HIGHER than stock due to the fact that GSR is heavier. It will not look pretty!
Yuri K
Old Aug 14, 2002 | 08:49 PM
drvfast's Avatar
yea if u use the gs-r shocks ur car will be higher.. i put the gs-r lca arms on my civic and also the gs-r anti swaybar it will bolt on there is no need to anything to the frame as long as u get all the pieces u need
Old Aug 15, 2002 | 09:12 PM
Default Re: suspension (drvfast)
How much higher is your ride now that you have teh gs-r lca's on? My car is about lowered about an inch and a half right now riding on 15" rota slipstreams. Am I going to have mad wheel gap or what?
killacam661
Dec 21, 2010 08:22 AM
gribbs
14
Mar 26, 2003 06:37 PM
hondaZvic
Dec 7, 2002 12:26 PM
DSC
Apr 15, 2002 07:52 AM
cold_blooded
Aug 16, 2001 05:59 AM
