For those with sway bars
I have a GSR front sway to be put on my 93 sedan. Now, I needed new endlinks so I got some from Energy suspension. However, they say on the back that they will not work with GSRs or Del Sol Vtec. Since I am using GSR bar but on a Civic, this is entirely unclear to me. Can someone tell me if I need specific GSR endlinks, or if these civic endlinks will work???? Looking at them, my GSR endlink has 3 bushings, the civic has 4. Maybe one should be omitted, I really don't know
Pleees help a fella in need
peace
peace
Re: For those with sway bars (gribbsEG8)
come on i never thought in a million years I could ask a question on here that could go unanswered....lots of you have GSR bars, are you using GSR endlinks or civic endlinks to fit your civic front suspension??????????
as for your question I am running STech sway bars but why dont you call ST or where bought the endlinks from and ask them?
Re: For those with sway bars (ITRacer121)
the place i bought them from only had civic in stock, and he knew no better then me
The guy i bought the bar from came from he GS teg and he suggested GSR parts....he does no his **** too....its a sick 1998 t3/t4
anyways we are leanin towards GSR endlinks ....can anyone clarify further?? thanx for the comments dudes!
GSR endlinks are different from si/ex civic endlinks. If the holes on your swaybar are vertical, you need gsr endlinks.
Re: For those with sway bars (CVC9216)
vertical holes?? holes are holes how can i tell if they are vertical ....i dont have an ex/si so....
Actually looking at the bar from the top you see no holes.....but that makes the endlinks stick horzontal, which i guess would make for horizontal holes????
wow i am still lost, someone must be able to confirm?!?!?!
If your car didnt come with a sway bar than you
will need controll arms. If it did then I dont think
that the civic controll arms can be used with the gsr
bar. This is why I sell them together. swaybar+controll arms
Re: For those with sway bars (d15dude)
If you lay the bar flat on the ground and look down on it and you can't see the holes, they're vertical. Vertical = up and down (|), horizontal = flat (---). Civic and GSR control arms are the same.
EDIT: GSR endlinks bolt through the swaybar at a right angle and have bushings on the control arm. Civic endlinks sandwich both the control arm and the swaybar with bushings.
[Modified by CVC9216, 12:09 AM 3/26/2003]
GSR front sway bar in an EG:
If you don't have an EX or Si EG, you'll need front LCA's from an ontegra, SI or EX from 92=95 civic hatch, coupe, or sedan. Doesn't matter
Once you have the LCA you have the hole needed for the endlinks to bolt up and your D bracket to bolt up also.
Anyways. GSR front sway bar is odd shaped at the end. You can not use an end link that goes up and down. You need an L shaped endlinks that was used on the gsr from the factory. The endlink has a pivoting ball joint which bolts to the sway bar, and the other end bolts to the lower control arm. You'll need that one. Specify GSR when ordering the part.
I was looking to replace the endlink rubber with polyurethane. No one makes a kit for the gsr endlinks, but I just reused the bushings provided by ES in my Hyperflex kit and it was a close enough fit to work on my gsr endlinks.
Hope I helped.
Hope I helped.
Thanks guys I did not know i needed Teg LCAs at all....now i know .....ya i dont think i need and entire endlink, just a couple poly bushings.....i have the civic endlinks those bushings could maybe do the trick
wont be goin on unless i can get lcas for cheap now i guess.....that kinda blows
dohcdelsol
06-01-2004 06:24 PM
