D16y8 engine
Old Mar 15, 2009 | 11:15 AM
obagain's Avatar
Default D16y8 engine
I have a 2000 honda civic with a d16y8 engine that finally dies on me so I bought an engine from ebay since I couldnt find one locally.
The engine numbers match but the manifold did not.
I contacted them and received an intake that fits but the wireing is different.
I dont work on cars and the mechanic isnt sure he can make it work.
Is there 2 different d16y8 engines for the 2000 civic?
They said it came out of a 2000 civic just like mine.
Is there any way to make this work or do I send it all back and start over?
Old Mar 15, 2009 | 11:27 AM
maddog20's Avatar
Default Re: D16y8 engine
why dont you use the intake manifold and wiring harness from your old Y8???
Old Mar 15, 2009 | 02:31 PM
obagain's Avatar
The vacuum is different.
The intake on mine has a vacuum chamber above the ports but the one on the engine I received does not have this,
The mechanic said there would be a vacuum leak if I tried to use it.
Old Mar 15, 2009 | 08:22 PM
SI_frankenstein's Avatar
Do you have pictures of both manifolds??
Old Mar 15, 2009 | 08:28 PM
candyman206's Avatar
are you talking about air injection? your engine should have air injection but if the new one doesn't then it's a 96-98.
Old Mar 16, 2009 | 04:12 AM
kyden's Avatar
why not have the mechanic reuse your old intake manifold?
Old Mar 16, 2009 | 06:26 AM
obagain's Avatar
This is the new one they sent.
http://i5.photobucket.com/albums/y15.../honda1001.jpg
That is the old one.
http://i5.photobucket.com/albums/y15.../honda1003.jpg
It is not easy to see the old one but you can see what I am talking about.
If the new engine is a 96-98 is there a way to make it work or is it better to send it back and start over?
Old Mar 16, 2009 | 07:01 AM
.dave's Avatar
i HAS questions ?
This thread is asking pretty much the same question. 99-00 Civic with a 96-98 longblock, he just put JB weld in the air injection holes on the 99-00 manifold.
http://www.civicforums.com/forums/18...o-fix-yet.html
Old Mar 16, 2009 | 08:46 AM
obagain's Avatar
But if I jb weld the hole will it throw codes?
What do you do with the line that is supposed to go there? Cap it off?
Do I have to change any of the chips or will it work right just like that?
Old Mar 16, 2009 | 10:05 AM
1992Si's Avatar
You can also check d-series.org for more help if you need it.
Old Mar 16, 2009 | 04:54 PM
obagain's Avatar
I am trying but all I get is people telling me to look other places.
Does anyone know the answer to my questions?
jujangero18
Sep 8, 2020 06:29 PM
c.j.604
Sep 16, 2014 12:12 PM
obagain
10
Mar 26, 2009 05:38 PM
X2BOARD
Apr 8, 2003 11:17 PM
