Does anyone know the part # for stock NGK spark plugs for the 96-97 Integra Type-R?
I'm gonna order the swap soon and I'm getting all the things that are going on the swap 1st. Should I stick with stock NGK plugs or go with the G rated or V rated? And what about NGK wires? thanks
ngk wires are great. the gsr and type r use the same plug which is a 6 heat range. heavy track use normally moves to a 7.
Off the top of my haed I believe the part number for the OEM plugs is PFR6G-11, 6 being the heat range, and 11 being the gap, 1.1mm.
NGK BKR6ES-11, or BKR7ES-11. Either will work fine, I personally run 7-heat range.
Running anything other than copper plugs in a B-Series is just silly.
central_driver
Feb 5, 2006 09:37 AM
jdmjeff
12
Nov 20, 2003 01:26 AM
