eagle rods torque spec.+arp mains
Old Mar 14, 2009 | 02:52 PM
poppypizza's Avatar
Default eagle rods torque spec.+arp mains
does anyone know it the exact number? H beam on the rod bolts it says arp, eagle, 2000, 1.5. I have seen people say 29 ftlbs up to 32+
Also does anyone know the arp main studs for b18b,, I called arp and he said i think 80 ftlbs with arp molly and 85 ftlbs without.. or the other way around,, can anyone confirm?
THANKS FOR THE HELP!
Old Mar 14, 2009 | 04:17 PM
poppypizza's Avatar
Default Re: eagle rods torque spec.+arp mains
waiting on someone with some info to start putting my motor together.
Old Mar 14, 2009 | 05:04 PM
SilverEk3dr's Avatar
If I remember right the sheet that came with mine said. torq them to 47 ft/lbs, break them loose. Torq them again to 47, break em loose again, and then for a final time torque them to 47 ft/lbs. Thats with the moly grease though
Old Mar 14, 2009 | 05:16 PM
poppypizza's Avatar
do you by any chance have the sheet around?? I dont have any moly grease
Old Mar 14, 2009 | 05:54 PM
http://www.arp-bolts.com/Tech/TechTorque.html
Go down to the general replacement and look at the 200-6209. Thats the bolts you have. It say 47 ft/lbs W/moly grease.
Old Mar 14, 2009 | 08:07 PM
poppypizza's Avatar
what about without molly grease?
Old Mar 14, 2009 | 08:20 PM
poppypizza's Avatar
and i have read its 75ft lbs i have also read 29 ft lbs.. anyone else?
Old May 12, 2009 | 04:09 PM
b20beast83's Avatar
anyone
Old May 12, 2009 | 05:01 PM
redlinetuning's Avatar
go with what the ARP tech told you .
Old May 12, 2009 | 05:33 PM
b20beast83's Avatar
without lube what would it be
eg 30 oil
mafia
24
Sep 30, 2009 09:37 AM
1993gsrcivic
May 21, 2008 11:51 AM
nikolass
Oct 3, 2006 04:48 AM
Nextelbuddy
Feb 12, 2004 12:39 PM
99B16Si
Nov 19, 2003 10:54 AM
