'00 EX rear drums -> discs conversion (w/o ABS)
Old Mar 14, 2009 | 12:43 PM
oroca's Avatar
Default '00 EX rear drums -> discs conversion (w/o ABS)
I have salvaged trailing + control arm /w disc brake assemblies from a '90 Integra GS. I have read other posts, namely in this thread:
http://forums.hondatuningmagazine.co...ion/index.html
saying that only 94-00 Integras are good, earlier is no good, but the '90 Integra stuff looks like exactly what I need.
From what I saw the pre-89 stuff is different, but 90 and up looks like it will work (based on the one I took, and another '92 Integra. They didn't have anything 94- or any SIs.
I took the e-brake cable from the same 90 Integra GS as well. Still need MC+booster, and proportioning valve.
I am thinking of taking back the trailing arms to exchange for that stuff, because I am not convinced I need them anyways and the bushings are both completely shot. If I change the lower control arm, I can use the sway bar I also took, but I am not sure if there are bolt holes in the undercarriage for that although I guess I could tap them...
Any idea if what I have so far will work or not? And what years would be my best bet for the MC/booster, and prop valve? Also, off topic but, if anyone has any idea how much a full bleed will take, let me know, because I am ordering some ATE Super Blue.
TIA for any advice
honvic21
Oct 1, 2008 04:46 PM
chinoty
Suspension & Brakes
Jan 1, 2007 01:03 PM
GserpleaSR
Aug 30, 2006 06:11 PM
AlienKrOZ
Nov 4, 2003 07:23 PM
MAD SCIENTIST
Mar 23, 2003 09:45 PM
