gsr problems in my ek
Old Mar 14, 2009 | 12:23 PM
bllabong89's Avatar
Default gsr problems in my ek
My car is smoking when idling and it pours smoke out when i get on it. i cant really describe the smell but its like brownish grey. any ideas??
Old Mar 14, 2009 | 12:35 PM
T3KNiQe's Avatar
Default Re: gsr problems in my ek
1) Do you have a cat?
2) How long has this been going on?
3) Any excessive oil burning?
4) Ever have to add coolant?
5) Hows your mpg?
6) Any check engine light?
Old Mar 14, 2009 | 12:42 PM
raidacaipo's Avatar
either timing is off or your running rich... or it could be both
Old Mar 14, 2009 | 04:27 PM
bllabong89's Avatar
i had a vafc. i just took that off and now am running a chipped p06 w/ no rev and no speed limiter. my heater core started leaking fluid on my floor boards so i have put fluid in it once. i dont have any CEL's. Oil level is good. it has been smoking for about 2 weeks. now my car is runing really rough. barely getting to idle at first. i have a cat but its hollowed out
Old Mar 14, 2009 | 07:35 PM
T3KNiQe's Avatar
Was it two weeks ago when you installed this chipped p06 ecu by any chance?
Old Mar 15, 2009 | 12:17 AM
bllabong89's Avatar
nah, ive had the chipped ecu for a couple years now but i just installed this motor over xmas break
Old Mar 15, 2009 | 01:16 AM
trustdestruction's Avatar
Is the chipped ECU set up to run a GSR?
If you got the chipped ECU a couple years ago and just installed the engine, I'm assuming it's not.
Old Mar 15, 2009 | 04:52 PM
bllabong89's Avatar
no, ive had a gsr in for a few years. i spun a rod so i bought another gsr engine and dropped it in and fixed the shitty wiring job from before. i was planning on building the other motor but now the car barely runs. i read on another forum that it could be irregular compression so maybe a blown head gasket? i just need some help, im gonna check the compression when i get the tester
Old Mar 15, 2009 | 06:29 PM
Oh ok, that makes more sense now. ECU can be crossed off the list of potential problems.
Not sure what it might be.
sh!ft
13
Mar 28, 2013 08:03 PM
Milab21
Engine Management and Tuning
Jul 16, 2009 03:14 PM
jdmjin
Aug 31, 2007 02:04 PM
Patch
Nov 8, 2003 11:28 AM
