smoke in car..
Old Mar 14, 2009 | 09:22 AM
mikehawk's Avatar
Default smoke in car..
I just went to grab a bite to eat on my lunch break ( at work obviously) I was chillin in my car eatting my taco bell and i see white smoke coming from the shift boot.. kinda smells like oil.. Where should I start to pinpoint this problem and what should I look for a leak ? is my tranny empty ? etc
Old Mar 14, 2009 | 09:27 AM
cmc600rr's Avatar
Default Re: smoke in car..
what color is the smoke? assuming your not sure its oil or not. Something is probably leaking onto the exhaust, check around the back of the motor and look for leaks.
Old Mar 14, 2009 | 09:33 AM
mikehawk's Avatar
white it is prolly oil .. I'll get under it tomorrow and see if is oil on my piping .. i just had new pipe and stock muffler put on should it should be easy to see. Any other suggestions?
Old Mar 14, 2009 | 09:35 AM
turboteg90's Avatar
pm for noodz
maybe its oil leaking from the oil filter area. keyword maybe.
Old Mar 14, 2009 | 09:40 AM
joshsayswhatt's Avatar
is it sweet smelling cause if so it's antifreeze, but if it's oily smelling check the oil pan gasket and like he said check where your exhaust and headers meet for any leaks
Old Mar 14, 2009 | 09:49 AM
mikehawk's Avatar
thanks guys I'll check all those things out tomorrow and see what I can turn up. My old jeep was leaking from the oil filter adaptor and it was such a bitch to fix there were 3 little orings which were easy to replace but the way the adapter is and the way it was facing and the type of tool you needed to get it off made it a pain in the ***. lol
Duhul
May 20, 2010 11:18 AM
nengx07
44
Feb 6, 2009 09:29 PM
xTimmyx
Oct 14, 2007 10:43 AM
itsJDMyo
21
Jan 19, 2004 05:58 AM
Gump
13
Nov 27, 2001 07:29 PM
