broken rear camber adjuster bolt head
i have no clue how to get this out the head is broken off flush and on the right side sticks out this is a basic picture not mine the lower left arrow
ya an easy out and its not so easy i tryed drilling it and using that vice grips anything and everything anybody else have an i idea i have school to drive to everyday and need to get this fixed
You could try using heat and heating the bolt and using vice grips to un screw the rest of the broken bolt.
Only other thing i could tell you to do is grab a air hammer bust off that welded on nut and run a lock washer with a new nut or re-weld on another nut.
the only other option is see if there is a nut on the other side and cut it off somehow, if not then you will have to buy a tap and drill the hole in the center of the bolt using the correct size drill which is found on a tap/drill chart
terqui
Aug 12, 2013 03:38 AM
Powered By Garrett
59
Jan 4, 2012 05:29 PM
