lsv build
Old Mar 13, 2009 | 09:37 PM
teggything's Avatar
Default lsv build
ok well i am building an ls vtec motor. and there is no acura dealer in town or anyone that can get me an gsr oil pump. my question is the b16 oil and water pump the same as the gsr?? i can get the b16 one from honda but i already have a gsr timing belt and almost everything else to finish my build. this is all thats holding me back lmk please
Old Mar 13, 2009 | 11:02 PM
teggything's Avatar
Default Re: lsv build
the write up for the ultimate lsv build says itr oil pump and vtec water pump j/w if i have to get the gsr since i bought the belt
Old Mar 13, 2009 | 11:08 PM
1990hf's Avatar
try this link
https://honda-tech.com/forums/showth...distributor+ls
Old Mar 13, 2009 | 11:27 PM
Steven.'s Avatar
The oil & water pumps on the vtecs are all the same.
Use the gsr timing belt because your block is 1.8 like the gsr.
The b16 belt would be too short.
Old Mar 13, 2009 | 11:50 PM
teggything's Avatar
i know i cant use the b16 belt i was just wondering about the pumps thx
Old Mar 14, 2009 | 04:54 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
This is not correct. OBD2 Integra oil pumps are all the same, 96-01 all models including ITR. But the OBD1 Integra oil pump is different. You can use an OBD2 pump on OBD1, but you have to modify the lower timing cover.
And the timing belt you use is determined by the water pump you use, NOT by what block or head you're using. B18B water pumps have 19 teeth, B18C1 pumps have 22 teeth. The B18C1 belt is longer as a result, and the B18C1 water pump spins slower, which pumps the water through better (less cavitation).
OP just order the parts you need online, like www.acuraautomotiveparts.org most likely it will be cheaper anyway.
To answer the question, 99-00 Si B16 water pumps were the same as 96-01 OBD2 Integra water pumps. OBD1 Integra and 93-95 del Sol VTEC water pumps had different part numbers, and I don't think they are interchangeable.
The 99-00 Si oil pump is also the same as 96-01 Integra oil pump. Same part numbers.
15100-P72-A01 OBD2 B16A/B18C1 oil pump
19200-P72-013 OBD2 B16A/B18C1 water pump
Old Mar 14, 2009 | 05:15 PM
teggything's Avatar
its going into an obd0 car my 90 DA so which pump would work without modifying my t/b cover???
Old Mar 15, 2009 | 06:17 AM
Community Builder
you probably want the OBD1 oil pump.
Old Mar 15, 2009 | 05:36 PM
teggything's Avatar
what pump should i ask for from honda? just ask for an obd1 vtec b series oil and water pump?
Old Mar 15, 2009 | 08:09 PM
teggything's Avatar
nvm im goig with the 95 del sol vtec oil and water pump
Old Mar 16, 2009 | 02:04 PM
teggything's Avatar
are the ls oil pumps the same??
1992db2
Jul 13, 2009 08:38 PM
1992db2
Jul 7, 2009 06:00 PM
KdF
Mar 10, 2009 05:36 PM
stevenDAtegra
Dec 15, 2008 07:53 AM
jDMJeRk
Jan 27, 2004 10:45 AM
