flywheel is loose
Old Aug 12, 2002 | 03:05 PM
lilcasino's Avatar
Default flywheel is loose
How the hell does my flywheel get loose? This is causing my car not to start. I can reach into the starter hole and move my flywheel in and out. Either it is cracked or loose, but how does this happen? Since it is going to be a 5 hour job it is getting a Comptech alum fw and a act hdss clutch.
Old Aug 12, 2002 | 05:07 PM
non-VTEC's Avatar
Default Re: flywheel is loose (lilcasino)
maybe it's broken? the ring gear separated from the flywheel itself.......
Old Aug 12, 2002 | 05:15 PM
sjk's Avatar
sjk
I recently repaired a civic with a loose ring gear. Starter wood spin gear only not
the flywheel so the car wouldn't start. I believe the this could have bean caused by
a bad starter or a poor slip fit of the gear to the flywheel.We welded it and everything turned out ok.
Old Aug 13, 2002 | 12:05 PM
lilcasino's Avatar
Default Re: flywheel is loose (sjk)
I am having the shop pull the tranny next week. Car only has 50k on it, seems werid that I would have this problem.
Old Aug 13, 2002 | 12:11 PM
GSRwBOOST's Avatar
Well.... how often do you beat the **** out of it?
Old Aug 13, 2002 | 12:21 PM
lilcasino's Avatar
Default Re: flywheel is loose (GSRwBOOST)
What would you call "beat the ****"? I dont rag on the car, it never gets driven that much anyway. I am the second ower though.
[Modified by lilcasino, 9:21 PM 8/13/2002]
AznPimpS
Nov 26, 2007 06:10 PM
del_parker
Nov 19, 2003 12:30 AM
Manguish
May 6, 2003 07:07 AM
typeRicer hater
Jan 9, 2003 12:56 AM
lilcasino
Aug 4, 2002 08:25 AM
