TPS voltage on DPFI
Old Aug 12, 2002 | 02:43 PM
JAMinCiViC's Avatar
Default TPS voltage on DPFI
My buddy just rebuilt his motor. It starts up fine but the idle fluctuates(sp) I checked all the vac hoses and i came to a conclusion on the TPS. I checked the voltage and it was .58, isn't it supposed to be .45 . What are the ways to adjust it ?? is the TPS jacked?? I read about tapping the rivet lightly would adjust it??
Old Aug 13, 2002 | 02:20 AM
kinesistech's Avatar
Default Re: TPS voltage on DPFI (JAMinCiViC)
The rivet that holds it on is a breakaway bolt. If you cut a slot in it with a dremel, you can unscrew it. Then move it a little to calibrate and retighten or replaced the bolts.
hadehatch
Dec 4, 2024 01:46 PM
Throwback23
May 4, 2010 09:33 PM
.hawaii
Nov 13, 2009 05:10 PM
Tizzakowack
Dec 12, 2008 02:06 PM
JAMinCiViC
Aug 12, 2002 04:08 PM
