LS turbo build up, stock block question
Old Mar 13, 2009 | 11:45 AM
fireblaze2k1's Avatar
Default LS turbo build up, stock block question
How much HP will the stock bottom end of a B18A1 with ARP rodbolts be good for? I want 200-225HP for a decent price without dropping $$$$ on building the bottom end.
Old Mar 13, 2009 | 12:01 PM
northemt88's Avatar
Default Re: LS turbo build up, stock block question
your goal is reachable,if you are not tuned i would not boost more than 8psi.Im boosted LS stock block untuned putting out 200 whp on 7psi
Old Mar 13, 2009 | 12:32 PM
hayn_integra's Avatar
With my stock turbo LS.. I hit around 260whp at 10psi. ANd 220whp at 6psi. So your goal is attainable.
Old Mar 13, 2009 | 12:39 PM
Whatever's Avatar
You don't need to do anything to the motor except to make sure it has good compression. Do a search on LS Turbo or look at the huge LS Turbo thread and you'll see plenty of people making 300 whp on 100% stock long blocks.
Old Mar 13, 2009 | 04:38 PM
Silva Bullit DC4's Avatar
Yep! (Check sig... ;-)
OP, your 2nd quote in your sig made me spit Dr. Pepper on my keyboard!
Old Mar 13, 2009 | 04:42 PM
Schister66's Avatar
Man U FTW
You have very attainable goals, but dont listen to people who give you goals in terms of PSI. That's a totally irrelevant measure. The safe range for your stock bottom end is ~300whp. Stay under that with a good tune and you'll be just fine
Old Mar 13, 2009 | 04:48 PM
TheShodan's Avatar
Moderator
^^^ I think I've counted you saying this same thing on about 4 threads so far.. man..
Old Mar 14, 2009 | 03:15 AM
I think I just might be catching up with Adam myself! ;-)
THELS98
Oct 6, 2005 07:30 PM
Ls91sI
Sep 28, 2005 12:51 PM
redlseg
Jun 23, 2005 02:38 PM
toeknee
Feb 25, 2002 01:59 PM
